RV.Net Open Roads Forum: How to increase water flow AFTER the filters?
 > How to increase water flow AFTER the filters?
Page of 5
down home
south
Posted: 07/31/20 12:18pm Link  |  Quote  |  Print  |  Notify Moderator
What will work is a large, larger the better sediment filter. They are the first to clog and cheapest to replace. Second a really good filter that gets all the nasties and metals and bugs or microbes. CW had a ten inch small diamter that would do that but now, you have to choose between metals and bugs and the filters cost more. A series of three filters with the first being for sediment and a second that gets metals and a third smal micron that gets what gets through the other two. The msot logical, sittign here and thinking right now, is a sediament filter then one good small micron carbon block filter with silver that gets all that the sediment filter doesn't get. Most sediment filters will get the chlorine too and the carbon block most certainly will.
They produce ultraviolet lamps in purification systems that kill all bugs, A tube carrying the water after filtering out everything runs around the bulb exposing it to uv.
I don't remeber distinctly but seem to remember long ago a psot about this in regards to use in an rv. Cot is the primary concern it seems...aand physical size.
Bumpyroad
Virginia
Posted: 07/31/20 02:06pm Link  |  Quote  |  Print  |  Notify Moderator
darleyhavidson wrote:
Interesting concept. What micron and style filters did you use? Do you have any pictures of your setup?
don't remember specifics, think it was a spun fiber one first to catch dirt, followed by a "good" (don't remember specs) one to remove bacteria and lead/etc.
I made my "connection" with PVC piping/fittings. as I recall, incoming water came into the PVC "T" which had two L fittings to the filters. it so happened that the T and Ls ended up being exactly the right distance apart to put the filters in parallel. will see if I can find the setup and take a pix. I used some quick disconnects to be able to easily assemble things.
bumpy
PA12DRVR
Back in God's Country
Posted: 07/31/20 03:11pm Link  |  Quote  |  Print  |  Notify Moderator
"I probably reduced the effectiveness of eliminating the sulfur smell by removing the metal trap filter, but at least the shower can be used now."
In my experience, which may not apply to where you are, sulfur smell and stink was best removed by a carbon filter...and the further upstream, the better.
FWIW, in years gone by, I've used a 20 micron upstream filter in series with a 10 micron...and our water tested fine out of the spigot. Theoretically, it won't make a flow difference (that's what the filter makers advertise anyway) but I don't believe you need three relatively fine filters in series. I currently use a 5 (not 0.5, but 5) micron at the house and it's all good.
CRL
My RV is a 1946 PA-12
Back in the GWN
jefjam7812
NY
Posted: 08/02/20 09:00pm Link  |  Quote  |  Print  |  Notify Moderator
Install more powerful moter
Page of 5
