RV.Net Open Roads Forum: Transporting Raft from Campsite to Launch Ramp?
 > Transporting Raft from Campsite to Launch Ramp?
ZINGERLITE
Union Lake, MI
Posted: 07/29/20 07:31am Link  |  Quote  |  Print  |  Notify Moderator
FlatBroke wrote:
Fold up wheels. Pick up the bow and pull it to the water and after it launched you flip them up and Be on your way. Works well.
I wonder if you could rig something up to tow that. like the waste totes. doesn't have to be a trailer hitch but some sort of loop to put over the ball.
valhalla360
No paticular place.
Posted: 07/29/20 11:56am Link  |  Quote  |  Print  |  Notify Moderator
If you are talking a 2-4hp outboard, consider a roll up or inflatable floor model. You aren't going to get on plane anyway, so the advantage of a RIB (and the weight that comes with it) goes away. You can find these in the under 100lb range, so getting it up on the truck cap is likely more viable.
If the cap has a ladder rack, you could probably set up a simple platform that could lean against the back of the truck and then winch up onto the cap rather than lifting. It would take a little bit of fabrication but shouldn't be too hard.
If you are just looking at getting from the campsite to the launch within the campground (ie: topping out at 5-10mph), the wheels that attach the transom are quite viable and wouldn't be hard to make up a set yourself.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Baja Man
Inland Empire, CA
Posted: 08/02/20 04:32pm Link  |  Quote  |  Print  |  Notify Moderator
wanderingaimlessly wrote:
Could something like this be modofied to pull to a ramp? Jet ski dolly
Check the different types of dollies on the web, some get pricey but some seem pretty reasonable.
There are some great ideas I am considering after looking at the jet ski trolleys.....many possibilities....?
2003 Ford F-350 XLT Super Duty, Crew Cab, V10 (6.8L); 4X2; Standard Bed; SRW; 4R100 trans
2009 Thor-MVP RV- Tahoe 284SA
Baja Man
Inland Empire, CA
Posted: 08/02/20 04:33pm Link  |  Quote  |  Print  |  Notify Moderator
Lakeland Bob wrote:
Have you considered one of these, http://www.4boysmfg.com/? If you already have the boat it would save money from buying another.
yes; my buddy just gave one away! I don't need anything that sophisticated.....I'm trying to keep it simple
Baja Man
Inland Empire, CA
Posted: 08/02/20 04:35pm Link  |  Quote  |  Print  |  Notify Moderator
ut
Grit dog wrote:
One of them Horrible Freight 4x8 folding trailers would do the trick. Store it in your toyhauler.
It would work, but but I'd like something lighter and simpler....that can be folded up and stored in back up my truck
Baja Man
Inland Empire, CA
Posted: 08/02/20 04:36pm Link  |  Quote  |  Print  |  Notify Moderator
Son of Norway wrote:
Back when I was young and strong I used to take people on whitewater raft trips. I had a 12' bucket boat and a 16' self-bailer that I transported on a trailer. I got the boats to the water by giving out a shout. In no time I would have all the hands I needed. Everyone helped each other at the launch sites. 175 lbs. should be no problem even for a long carry.
Not willing to carry.....simple trolley that can be towed with my truck hitch is what I want
Baja Man
Inland Empire, CA
Posted: 08/02/20 04:37pm Link  |  Quote  |  Print  |  Notify Moderator
ZINGERLITE wrote:
alot of jet ski guys build carts out of pvc pipe. light weight and easy to transport.
PVC is on my short list f ideas.....
BTW...your posted image can not be viewed
Baja Man
Inland Empire, CA
Posted: 08/02/20 04:40pm Link  |  Quote  |  Print  |  Notify Moderator
Do you tow it behind your truck to ramp? I would be concerned about boat transom with all the bouncing.
I would like trolley to be able to:
-towed behind my truck
-quickly and easily be able to deconstruct/construct
-light weight
Baja Man
Inland Empire, CA
Posted: 08/02/20 04:43pm Link  |  Quote  |  Print  |  Notify Moderator
How do you like your Saturn?
Is your use similar to my intended uses?
Any suggestions, advice on purchasing a Saturn?
Considering the FB365....
Saturn FB 365
Elk_traveler
maryland
Posted: 08/02/20 05:11pm Link  |  Quote  |  Print  |  Notify Moderator
We have similar interest in fishing. Unless we're on a sightseeing mission we camp primarily in state parks and primarily those that offer good fishing. I am an avid hunter for good large mouth bass fishing. Just enjoy the sport because I am only interested in catch and release as a sport. My RV is now a Class C and car in tow. I have a small porta bote which I carry on top of toad and initially had same problem as you in how to get the boat once set up down to the river or lake. I solved this by purchasing a small trailer manufactured by Trailex.com. I have the model SUT-300 all aluminum and can be fully assembled in some 15 minutes. Basically two tires, axle, tongue in two pieces. Very simple I think the SUT-300 can carry up to 300 lbs. It is strictly for off road use. As long as I stay within the Park limits there is no issue in towing the boat down to the launch ramp. Trailex.com makes many different style trailers which you can see on their website. Once at campsite I assemble the porta-bote and the trailer and go back and forth fishing until we are ready to leave. I think the total weight for me on the trailer is only perhaps 150 lbs once I have loaded everything I will need when out on the water. I have been using the Trailex trailer for perhaps 8-10 years and its ideal for the life style we like. When we are camping there has to be good fishing nearby.
