RV.Net Open Roads Forum: Which is better 60 amp converter or 1000 watt inverter
 > Which is better 60 amp converter or 1000 watt inverter
jimbo4UT
Stafford Virginia
Posted: 07/29/20 11:53am Link  |  Quote  |  Print  |  Notify Moderator
Man this stuff makes my head ache [emoticon]
thanks in advance
Yaj
The Milky Way Galaxy (Fort Myers, FL)
Posted: 07/29/20 11:56am Link  |  Quote  |  Print  |  Notify Moderator
Apples and oranges
time2roll
Posted: 07/29/20 12:07pm Link  |  Quote  |  Print  |  Notify Moderator
Depends on what your situation is. More important is the charging voltage and duration. Most RVs would get on fine with less power. You may even want to limit power if the generator is small.
So post what your concerns are to consider.
675w Solar pictures back up
bob213
Fresno, CA
Posted: 07/29/20 12:10pm Link  |  Quote  |  Print  |  Notify Moderator
Depends on what you are trying to do.
Converter changes 110v ac to 12v dc.
Inverter changes 12v dc to 110v ac.
Mono Basin National Forest Scenic Area
Posted: 07/29/20 12:24pm Link  |  Quote  |  Print  |  Notify Moderator
Xs and Os. You must have a converter. You might want an inverter.
elwood58
Orange County CA
Posted: 07/29/20 12:33pm Link  |  Quote  |  Print  |  Notify Moderator
You need a converter to convert 110v AC to 12v DC in order to charge your batteries and power 12v DC lights and appliances when on shore power.
You need an inverter to make 12v DC into 110v AC for running AC appliances from your battery bank.
There are combo units that do both, but can be large and expensive. If you have a working converter, and only need to add an inverter, make sure it is Pure Sine Wave output, and sized large enough to handle your projected load.
2016 Fleetwood Bounder 33C
rk911
DuPage County
Posted: 07/29/20 12:38pm Link  |  Quote  |  Print  |  Notify Moderator
if you're replacing a converter/charger please look for a 3-stage or "smart" charger. this will help protect your coach batteries from overcharging which should extend battery life. the converter/charger does two things. it channels power from the shore power connection or generator to charge your coach batteries (and in some RVs the chassis battery(ies) as well). it also converts the 120vac shore power or genny power to 12vdc to power your lights, RV fridge and other 12v items in your RV.
you only "need" an inverter if you want to power one or more 120vac appliances such as a microwave, microwave/convection oven, TV, other entertainment devices or residential refrigerator while not plugged into shore power or running your generator. the more 120vac appliances you want to simultaneously power through the inverter will determine the size of inverter needed which in turn will help you decide how big of a battery bank you need.
Rich
Ham Radio, Sport Pilot
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
jimbo4UT
Stafford Virginia
Posted: 07/29/20 12:44pm Link  |  Quote  |  Print  |  Notify Moderator
It is starting to get clearer [emoticon] Thanks everyone
pianotuna
Regina, SK, Canada
Posted: 07/29/20 12:54pm Link  |  Quote  |  Print  |  Notify Moderator
thanks in advance
If you are trying to compare a converter with an inverter/charger, often the inverter/charger is more flexible about adjustments to charging parameters.
Before the advent of hybrid inverter/chargers, I preferred a stand alone converter and a stand alone inverter.
Regards, Don
valhalla360
No paticular place.
Posted: 07/29/20 02:04pm Link  |  Quote  |  Print  |  Notify Moderator
Assuming your trailer currently has neither...I would go with the Converter (RV name for battery charger). Otherwise, once your battery is drained, you are completely out of electricity (I'm presuming no other charging source and not hooked up to shore power)
Of course, in real life it's apples vs clydesdales...they are two completely different things...other than clydesdales like to eat apples.
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
