RV.Net Open Roads Forum: 2020 Jayco GrayHawk Prestige 29 MVP Water Overflow?
 > 2020 Jayco GrayHawk Prestige 29 MVP Water Overflow?
jolooote
Miami, FL
Posted: 07/29/20 03:51pm Link  |  Quote  |  Print  |  Notify Moderator
Since I got my new cement pad I've been under the coach for the 1st time. Good look at the Fresh Water tank. I don't see any Fill Overflow drain hose??? Just Low Point drains. This is my 5th Motorhome and all have had Overflow hose in case I over fill it it, it won't turn the tank into a giant water Balloon till it explodes. Any clues? [emoticon]
Joe & Charlotte
2020 Jayco Greyhawk Prestige 29MV Celestial Blue Full Body Paint E-450 305hp V10 6spd Class C 'COACH'
2012 Jeep Wrangler 285hp V6 'TOAD'
Gabby & Molly are Dogs
Leroy's a Conure, Loretta's a Squeaker
"Once it starts breakin'...GET RID OF IT!!!"
VA-Apraisr
glen allen, VA
Posted: 07/29/20 04:06pm Link  |  Quote  |  Print  |  Notify Moderator
Probably a quick fix by drilling your own and running the line over to the fill up door. Most parts available at Lowe's or plumbing store. I replaced mine and put an on/off valve in the line so I don't keep loosing water on sharp turns as I've been doing (usually lose 10+ gallons by the time I get to my drycamping site). Last weekend, didn't loose hardly a drop.
dougrainer
Carrolton, Texas
Posted: 08/01/20 05:39pm Link  |  Quote  |  Print  |  Notify Moderator
just fill the tank and then when it gets close to full, drop the water to a trickle and then observe where the water comes out. Jayco DOES vent the tank. Doug
cross21114
Baltimore, MD, USA
Posted: 08/02/20 07:47am Link  |  Quote  |  Print  |  Notify Moderator
Do you have a little hole next to the water connection? I no longer trust my overflow which had a large bug crawl in it and die. M tank did swell up. Fortunately, caught it without damage (I have nightmares about that).
Our tank is under the master bed. Now I lift the bed and watch the water level as it fills.
Chris
2018 Nexus Ghost 36DS
360 Cummins, 3000 Allison
2016 Ford Expedition
dougrainer
Carrolton, Texas
Posted: 08/02/20 02:55pm Link  |  Quote  |  Print  |  Notify Moderator
His Jayco does not have a gravity fill. It fills from the City water connection. Doug
cross21114
Baltimore, MD, USA
Posted: 08/02/20 05:33pm Link  |  Quote  |  Print  |  Notify Moderator
Mine does also. There is a selctor valve for filling, normal usage (with water pump), city and winterize. Next to the hose connection, there is a hole which is the overflow.
bobndot
Posted: 08/02/20 07:35pm Link  |  Quote  |  Print  |  Notify Moderator
No real gravity fill anymore ? Hmm , maybe it's time to carry an extra pump in case the pump goes south.
I started carrying an extra pump when my OEM pump died on Sat noon of a holiday weekend 75 miles from rv help.
Its $79.00 insurance and you can keep the extra pump if you change rvs.
jolooote
Miami, FL
Posted: 08/08/20 09:11pm Link  |  Quote  |  Print  |  Notify Moderator
Problem Solved! There IS drain hoses. 3 small hoses extend down from the top of the fresh water tank on the left (Drivers) side of the tank.
