RV.Net Open Roads Forum: General RVing Issues: Simple extension cord
 > Simple extension cord
HighwayJunky
Crestview
Posted: 07/29/20 05:41pm Link  |  Quote  |  Print  |  Notify Moderator
Wife, wants to take our 42' MH to sisters home for a visit. Wants to use extension cord to simply run refrigerator keeping food safe. Otherwise we do our necessaries in the sisters home.
Really !! Can this be done?? How???
2015 Itasca Ellipse 42QD
2012 Fiat Pop Toad
One wife
No pets
No complaints
No Worries (except keeping wife happy!!)
Fulltime jobhttps://www.rv.net/SharedContent/cfb/images/rolleyes.gif
enblethen
Moses Lake, WA
Posted: 07/29/20 05:50pm Link  |  Quote  |  Print  |  Notify Moderator
Somewhat easy to do!
I am guessing you have a 50 amp detachable. If not I will revise what I show.
Big question is how far are you having to run cord?
A fifty amp twist lock to 15 amp Adapter
Now the cord minimum #12
This would keep your big cord in rig!
Non-detachable cord would use adapter Adapter
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
opnspaces
San Diego Ca
Posted: 07/29/20 05:52pm Link  |  Quote  |  Print  |  Notify Moderator
It should be as simple as an extension cord plugged into an outlet in the house. At the RV end use a 15 amp to 30 amp adapter. If you have a 50 amp rig plug a 50 to 30 amp adapter in.
Turn off the AC.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
cavie
Posted: 07/29/20 05:55pm Link  |  Quote  |  Print  |  Notify Moderator
You need to purchase a 12 ga heavy duty extension cord. Also purchase a 15/30 dog bone. Amazon is your friend. You need to plug into a NON-GFI'ed circuit.
edited 9 pm
yes If you have a 50 amp rig. You need a 15/50 or a 30/50 + 15/30
* This post was edited 07/29/20 06:58pm by cavie *
Matt_Colie
Southeast Michigan
Posted: 07/29/20 06:00pm Link  |  Quote  |  Print  |  Notify Moderator
As enblethen said, this is very do-able, but with a warning.
Set up the 6-15 to 14-50 (wall plug to RV) adapter and then go into your AC distribution panel and open the breakers for everything you don't need to leave powered up. That will be at least:
Power to all A/Cs
Power to the water heater
Galley power (Microwave, coffer maker and what all) If you can't separate these, PLUG THE plugs.
Be sure to leave power to the reefer and the converter.
It is almost a given that someone will try to use something that will pop that breaker if you leave power available.
Matt
Matt & Mary Colie
A sailor, his bride and their black dogs going to see some dry places that have Geocaches in a coach made the year we married.
DrewE
Vermont
Posted: 07/29/20 06:01pm Link  |  Quote  |  Print  |  Notify Moderator
If everything in the RV is up to snuff, there's no reason why a GFCI outlet shouldn't work fine, in the vast majority of cases at least. Most times when an RV trips a GFCI it's due to an actual problem somewhere: a neutral/ground short, or a leaky heating element in the fridge or water heater, or what have you.
(You need hundreds of feet of wiring for capacitive coupling to become sufficient to trip a GFCI, or maybe a dozen or so electronic devices with three prong plugs and RFI filters.)
cavie
Posted: 07/29/20 06:55pm Link  |  Quote  |  Print  |  Notify Moderator
As a master electrician Ii did side by side testing on my 2 trailers. It has also been verified by many others on different forums. Lots of times 2 GFI outlets in series do not play nice. Neither of my trailers would work on with 2 GFI's in series. Either turn off the RV gfi circuit or plug into a non gfi outlet and everything was fine.
time2roll
Posted: 07/29/20 07:20pm Link  |  Quote  |  Print  |  Notify Moderator
Yes. Not even a big deal. Although I do recommend a cord with #12 wire. Up to 100' is fine.
Make sure the water heater is off or set to propane. Use all the lights you need.
675w Solar pictures back up
pianotuna
Regina, SK, Canada
Posted: 07/29/20 07:48pm Link  |  Quote  |  Print  |  Notify Moderator
I often do run from a single 15 amp shore power circuit. I have used up to 250 feet of #10 wire--but that is over kill for just the fridge and converter.
Another (more expensive) route is to have a hybrid inverter/charger that allows load support. I love mine and would recommend Victron or Outback.
Regards, Don
ajriding
st clair
Posted: 07/29/20 08:25pm Link  |  Quote  |  Print  |  Notify Moderator
Or, pull the cover off the fridge outside door, unplug the fridge from the wall outlet and plug in your fridge to the extension cord. You will only have power to the fridge, but that is all you are wanting while you stay inside a house...
