RV.Net Open Roads Forum: General RVing Issues: Simple extension cord
 > Simple extension cord
enblethen
Moses Lake, WA
Posted: 07/29/20 08:39pm Link  |  Quote  |  Print  |  Notify Moderator
OP will need a good source of 12 volts DC for the refer control. He could drain his battery(ies) enough to shut down the rig.
OP: we need to know what kind of 50 amp connection you have to your rig.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Edd505
Elephant Butte, NM
Posted: 07/29/20 08:42pm Link  |  Quote  |  Print  |  Notify Moderator
ajriding wrote:
Or, pull the cover off the fridge outside door, unplug the fridge from the wall outlet and plug in your fridge to the extension cord. You will only have power to the fridge, but that is all you are wanting while you stay inside a house...
Simplest answer with no chance of damage to other electronics.
(I do have all that adapters 50-15 and did run just the fridge full time until I did the 30amp to the carport)
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
JRscooby
Indepmo
Posted: 07/30/20 04:36am Link  |  Quote  |  Print  |  Notify Moderator
Maybe another plan. Is the fridge hardwired, or does it plug into a outlet in the camper?
Use a heavy cord, work it in thru any opening, edge of slide out, window or door. Plug fridge into the cord, and no other load will be on the cord...
Wherever I happen to park
Posted: 07/30/20 04:38am Link  |  Quote  |  Print  |  Notify Moderator
Have done it. Run fridge on propane to lessen load on cord
I used a 100' 12 Ga Extension cord from Sears/K-Mart but alas those are hard to find. (The cord has a push button on the outlet so it "Grips" what's plugged into it. You can get 12ga extension cords at Lowe's Mennards and Home Depot however I do suggest 12 ga.
In my case I have a plug in converter so ONLY the converter was connected. the other stuff that uses 120 volt ate off the inverter (Televisions, Computers, related electronics some fans and the kitchen stuff but it ate generator power)
Home is where I park it.
garyemunson
Reno, Nevada
Posted: 07/30/20 05:41am Link  |  Quote  |  Print  |  Notify Moderator
Like said above, turn off breakers for the A/Cs, water heater and microwave. The BIG problem is that it often WON'T trip a breaker. What usually fails first is one end or the other of the extension cord,. The extra draw can easily turn a wall outlet in the house to toast before a breaker trips.
HighwayJunky
Crestview
Posted: 07/30/20 07:12am Link  |  Quote  |  Print  |  Notify Moderator
Couple points I should have mentioned in the very beginning..Blame it on inexperience I guess!
1) coach is ALL ELECTRIC.
2)50AMP service
2015 Itasca Ellipse 42QD
2012 Fiat Pop Toad
One wife
No pets
No complaints
No Worries (except keeping wife happy!!)
Fulltime jobhttps://www.rv.net/SharedContent/cfb/images/rolleyes.gif
enblethen
Moses Lake, WA
Posted: 07/30/20 07:20am Link  |  Quote  |  Print  |  Notify Moderator
Does it have detachable shore power cord?
JoeH
Apollo Beach,FL
Posted: 07/30/20 07:21am Link  |  Quote  |  Print  |  Notify Moderator
not sure if you have a residential or rv frig. Regardless, should work OK. One thing to consider is if you have an EMS, you should change the input setting to 15 amps otherwise with the 50 to 15 adapter, it with think it's on 30 amp service and will try to power things ( i.e. battery charger) up to the 30 amp limit and will trip the 15 amp breaker in the house.
Joe
2013 Dutch Star 4338- all electric
Toad is 2015 F-150 with bikes,kayaks and Harley aboard
pianotuna
Regina, SK, Canada
Posted: 07/30/20 09:01am Link  |  Quote  |  Print  |  Notify Moderator
All electric will be fine. Monitor voltage. If there is a hybrid inverter/charger that would be great.
Dial the input amperage down. I prefer 12 amps on a 15 amp service.
Regards, Don
Deb and Ed M
SW MI & Space Coast, FL USA
Posted: 07/30/20 02:59pm Link  |  Quote  |  Print  |  Notify Moderator
Just a little hint - if your extension cord has to cross a sidewalk, tape it with hi-vis duck tape so nobody trips on it. We used to camp at my Bro-in-laws, parked in the street a la "Cousin Eddie". Fortunately, it was a cul-de-sac; and he had very nice neighbors :-) (no - we did NOT dump the tanks down the storm sewer....LOL!)
