RV.Net Open Roads Forum: General RVing Issues: Simple extension cord
 > Simple extension cord
PartyOf Five
Wheaton, IL
Posted: 07/30/20 08:25pm Link  |  Quote  |  Print  |  Notify Moderator
ajriding wrote:
Or, pull the cover off the fridge outside door, unplug the fridge from the wall outlet and plug in your fridge to the extension cord. You will only have power to the fridge, but that is all you are wanting while you stay inside a house...
x2
Da Moose:2001 31' E450. 30k in 3yrs- 45 states, 9 provinces
PartyOf5: Driver's DW & 3 pre-teens -trying to connect, learn, appreciate creation & the Creator
May you find Peace in all that you endeavor
JAC1982
Brighton, CO
Posted: 07/31/20 01:01pm Link  |  Quote  |  Print  |  Notify Moderator
We have ours plugged in right now in our barn to a regular wall outlet using an adapter. It's just to keep the ceiling fan running and the ability to have lights and occasional water pump use (when we're too lazy to go inside the house to use the toilet). We've ran the fridge before this way as well to get ready for a trip, but as we have a month before our next one, it's currently off. No way would we try to use ACs or anything else.
We have a 50AMP outlet but it's on the "wrong" side of the barn and requires a long extension cord. So this is easier.
2020 Keystone Montana 294RL
2017 Ford F350 DRW King Ranch
Posted: 08/01/20 10:38am Link  |  Quote  |  Print  |  Notify Moderator
OP, it would behoove you to learn a bit about your RV systems rather than just plug n play in ignorant bliss.
You haven’t answered the fridge question yet, even.
RockyMt
Castle Rock Colorado
Posted: 08/01/20 07:25pm Link  |  Quote  |  Print  |  Notify Moderator
I have mine plugged into 20amp all the time, never use air when stored. Keeps the batteries charged.year around- 50amp trailer
pianotuna
Regina, SK, Canada
Posted: 08/01/20 10:08pm Link  |  Quote  |  Print  |  Notify Moderator
This works, until the house battery goes dead. Then it doesn't.
Regards, Don
down home
south
Posted: 08/01/20 10:35pm Link  |  Quote  |  Print  |  Notify Moderator
Use the 50 to 30amp adapter and 30 to heavy duty extension cord and hopefully the plug is connected to a 20 amp breaker.
Posted: 08/02/20 01:00pm Link  |  Quote  |  Print  |  Notify Moderator
Aaaand OP hasn’t been back.....
JRscooby
Indepmo
Posted: 08/02/20 03:39pm Link  |  Quote  |  Print  |  Notify Moderator
How much 12 V power does the fridge use?/How long house battery last? And if this was a issue could hook a small power supply to that circuit.
pianotuna
Regina, SK, Canada
Posted: 08/02/20 04:43pm Link  |  Quote  |  Print  |  Notify Moderator
My RV parasitic loads amount to 35 amp-hours per day. Of that, my "guesstimate" is, given the 2:3 duty cycle of an absorption fridge (measured), about 20 amp-hours to run the fridge.
time2roll
Posted: 08/02/20 04:55pm Link  |  Quote  |  Print  |  Notify Moderator
Converter and fridge combined uses maybe 4 amps on that cord and 15 amp supply.
May as well plug in the main cord. Even the lights will not be a issue to get set in for the evening.
675w Solar pictures back up
