RV.Net Open Roads Forum: Converter on Pace Arrow 99 model K35 Inteli Power 9100
 > Converter on Pace Arrow 99 model K35 Inteli Power 9100
BENTARROW21
Lakewood, Co
Posted: 07/30/20 03:23pm Link  |  Quote  |  Print  |  Notify Moderator
Problems with batteries, house and engine going dead. All batteries are new, not charging from generator or shore power. Repair manual says converter, we are still looking for it....would like to use the motor home again this year.
* This post was last edited 07/31/20 11:33pm by an administrator/moderator *   View edit history
dougrainer
Carrolton, Texas
Posted: 07/30/20 05:39pm Link  |  Quote  |  Print  |  Notify Moderator
On some older Fleetwood's, the Converter is located BEHIND the overhead 120 breaker/12 volt fuse panel. Doug
tommy g
West Georgia
Posted: 07/30/20 06:44pm Link  |  Quote  |  Print  |  Notify Moderator
Mine is accessed in an outside compartment.
1998 Bounder 36s F53 460 V8 Banks power & Honda Accord toad
MountainAir05
New Mexico
Posted: 07/31/20 09:47am Link  |  Quote  |  Print  |  Notify Moderator
Try under the bed.
1492
Arlington, VA
Posted: 07/31/20 07:27pm Link  |  Quote  |  Print  |  Notify Moderator
enblethen wrote:
Converter is commonly located in void behind the power distribution panel.
Majority of gas Pace Arrows have a battery control center under the hood. It it is a paralleled set of circuit breakers that send power to the 12 volt power distribution center.
There should be two battery disconnects. One for chassis battery and one for the coach batteries,
In the 12 volt power distribution panel is a main BAT fuse. Check it for power.
The converter could have reverse polarity fuses on the end where the large 12 volt cables come out.
The converter is fed from the 120 volt AC power distribution panel. Reset all circuit breakers. Turn them all off by shutting them off applying light pressure toward off. Turn on main circuit breaker followed by branch breakers one at a time.
Model should be M-35K, correct?
Check the main 12 volt fuse for power. If converter is operating properly, it should be putting out around 13 volts.
BENTARROW21
Lakewood, Co
Posted: 08/01/20 09:19am Link  |  Quote  |  Print  |  Notify Moderator
Thank you, I will have to examine the 12 volt panel area more closely. I may be thinking the converter is larger than it actually is. It's hard when you are not sure what your looking for. Thanks again.
