RV.Net Open Roads Forum: Minimum gate opening width needed for TT parking........
 > Minimum gate opening width needed for TT parking........
Mono Basin National Forest Scenic Area
Posted: 07/30/20 05:51pm Link  |  Quote  |  Print  |  Notify Moderator
Is lion now selling Scamps? lol
msmith1.wa
Tacoma, WA
Posted: 07/30/20 06:40pm Link  |  Quote  |  Print  |  Notify Moderator
Depending on which side the house is on you will need to account for the awning also. About six more inches.
2003 Silverado 2500HD 4x4 8.1l
2016 Evergreen Amped 28FS
corvettekent
Marysville, WA
Posted: 07/30/20 08:26pm Link  |  Quote  |  Print  |  Notify Moderator
If the eve is going to be on the drivers side as you are backing in you shouldn't have a problem. If the eve is on the passenger side you will hit it at some point in time, so you might as well fix it now before you damage both the eve and the trailer.
2007.5 GMC Dually EC/LB, LMM. Banks IQ, Speed Brake, Six Gun. B&W Turnover Ball, Companion Hitch, Amp power steps. Hadley Air horns.
2004 32' Carriage 5th wheel. 860 watts of solar MPPT and four 6 volt batteries. Samlex 2,000 watt Pure Sine Wave Inverter.
Beverley&Ken
Tottenham,Ontario
Posted: 07/30/20 08:27pm Link  |  Quote  |  Print  |  Notify Moderator
Double check your clearances, clearance after the gate is opened to the eave and how high up is the eave. If it is a straight run at it, should be doable. Don't forget the mirrors on the tow vehicle, they probably will have to be folded in until clear.
When looking at the trailers, remember that the box width stated is NOT the total width of the complete unit. It may state 7'6, 8'0 or even 8'6". (102"). Our RV is 8'6" wide plus awning on one side and slide toppers on the other, thereby requiring a clearance of almost 9'.
Ken
2006 Winnebago Outlook 29B E-450.
2012 Honda CR-V AWD
Blue Ox Aventa LX tow bar and Brake Buddy Vantage.
TurnThePage
North ID
Posted: 07/30/20 11:11pm Link  |  Quote  |  Print  |  Notify Moderator
I made sure the post on my gate was right under the eave, preventing my trailer from hitting the eave without also hitting that post. My gate width is 10 feet. I've been backing through it with a standard 8 foot wide trailer for over 16 years. It's not difficult, especially if your approach is straight. You should be able to see both sides with your mirrors. Just take it slow.
I actually have to round a tight corner, then line up with that gate with very little room for maneuvering. It can take 10 or 15 minutes.
2015 Ram 1500
2004 Pioneer 18T6
valhalla360
No paticular place.
Posted: 07/31/20 04:33am Link  |  Quote  |  Print  |  Notify Moderator
It's not a lot of spare room but certainly enough if you can hit it straight.
Now if there are odd turns on either side of the gate, all bets are off.
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
Bumpyroad
Virginia
Posted: 07/31/20 05:44am Link  |  Quote  |  Print  |  Notify Moderator
buy a 7 or 7 1/2 ft wide trailer. back it in straight and buy a small motorized dolly to inch it thru the opening.
bumpy
pennysmom09
Delaware
Posted: 07/31/20 06:05am Link  |  Quote  |  Print  |  Notify Moderator
We have a 5th wheel and a 9ft wide gate to our backyard. We backed in very very slowly because the clearance is mere inches. Ours is adjacent to our house too, with roof of Rv same height as gutters. Talk about stress!! Our gutters have a few dents from the initial efforts! We did get good at it though!
Nancy and Doug
2015 KZ Durango 325RL FW
Terry 25
Hagerstown, MD
Posted: 07/31/20 08:08am Link  |  Quote  |  Print  |  Notify Moderator
We have an 11' driveway with the house on one side and a chain-link fence on the other. Two below grade window wells intruded about 18'' into the space. 25ft TT not bad getting in but harder to get out. Real trouble was when you wanted access, the fence made it impossible to fully open the door. {It was a no slide model). We lived with it for 12 years. Bought a 30 footer and rented a storage lot. Best $45 I ever spent even tho it's 11 miles from home. Stress - free coming and going. Sure wish we could store it at home but "the juice wasn't worth the squeeze".
2016 F-250 Gas
2015 Rockwood 2608WS
wapiticountry
Mountain West
Posted: 07/31/20 08:32am Link  |  Quote  |  Print  |  Notify Moderator
The physics of the clearance changes if it isn't completely level the whole way in. Tilt one way of the other and those measurements will change. And, like another poster noted, if you have to execute any turns all bets will be off.
