TechWriter
On The Road
Our park electrician says that some of the big rigs with 3 ACs and electric everything can sometimes draw more than 50A from a 50A pedestal.
Truth or BS?
2001 Newmar Mountain Aire 4095 DP
Part Timer 2004 - 2013
Full Timer 2013 - 2020
Part Timing Again
www.rvSeniorMoments.com
DISH TV for RVs
enblethen
Moses Lake, WA
Wired properly, BS!
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
fcooper
St. Augustine, Florida
100 amps available....50 amps per leg x 2 legs...so answer is yes
Fred & Vicki
rk911
DuPage County
i've heard of but not seen in person RVs with 100-amp service. connected to a 50-amp post i believe the most a rig like thar could draw would be a bit less than 50-amps else the post CB would trip.
Rich
Ham Radio, Sport Pilot
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
mobeewan
Hampton, Va
fcooper wrote: 100 amps available....50 amps per leg x 2 legs...so answer is yes
fcooper is right. You are not thinking about how a 50 amp / 240 Volt system works.
You have 2 120 volt legs with 50 amps available on each leg not 25 amps on each leg. 50 + 50 =100 amps of 120 volt power.
time2roll
Three? Each is maybe 16 max so even 4 would pull only 32 per side max.
Licensed electrician or handy man?
675w Solar pictures back up
mtofell1
Oregon
Stating an amperage without specifying the voltage is really only describing part of the story. More than 50A @ 120V? Sure. More than 50A @ 240V? Sure... for a few seconds until the breaker pops.
Honestly, RV power is listed in kind of a messed up way and it rarely gets clarified. A 30A hookup is 120V. A 50A hookup is 240V. So, if you just want a linear scale for comparison sake, a 30A hookup is 30, a 50A hookup is 100.
Mont G&J
Missoula, MT
Park electrician is correct.
pianotuna
Regina, SK, Canada
Add up all the possible loads. Neither leg will exceed 50 amps I suspect--but there are 2 legs.
In winter I can draw more than 50 amps--but it is shared over both legs.
Regards, Don
MEXICOWANDERER
las peƱas, michoacan, mexico
Electrical must always be designed for worst case.
Aside from water heater, reefer and battery recharging it is quite possible for a park power blip to knock all A/C off line. Then all of them may attempt a high head re-start. If the park is nearly full, the park becomes an involuntary appliance durability tester.
