RV.Net Open Roads Forum: Tech Issues: Pulling more than 50 amps ?
 > Pulling more than 50 amps ?
Page of 11
fj12ryder
Platte City, MO
Posted: 07/31/20 07:32am Link  |  Quote  |  Print  |  Notify Moderator
dougrainer wrote:
Mont G&J wrote:
Park electrician is correct.
Park Electrician is a ignorant idiot. 50 amp service is 100 amps TOTAL supply. 50 amp service on EACH LEG. Doug
Okay, I'm confused. What's the difference between what you're saying "100 Amps total" and what the park electrician said "more than 50 Amps from the pedestal"?
Howard and Peggy
"Don't Panic"
Bill.Satellite
Full-timer
Posted: 07/31/20 07:46am Link  |  Quote  |  Print  |  Notify Moderator
If you look at a 50 amp breaker you will see that it is actually 2 breakers tied together so that if either side trips (exceeds the 50 amp load) both sides trip. Now it can trip if you are too close to 50 amps for too long but the theoretical load is 50 amps from each breaker.
Another way to understand 30 amp vs. 50 amp service is to understand the total watts available. 30 amp service is 30 amp x 120V = 3600 watts. 50 amp service there are 2 separate 50 amp "legs" for a total of 100 amp. 100 amps x 120V = 12000 watts available.
What I post is my 2 cents and nothing more. Please don't read anything into my post that's not there. If you disagree, that's OK.
Can't we all just get along?
Lynnmor
Red Lion
Posted: 07/31/20 07:47am Link  |  Quote  |  Print  |  Notify Moderator
Calling the guy an ignorant idiot is just plain wrong. It is entirely possible that a large RV with 3 AC's to draw more than 50 AMPs on one leg. An RV with 3 AC's probably has a laundry, large refrigerator and possibly a dishwasher and numerous other appliances. It doesn't matter how much the other leg is drawing, the breaker trips if just one exceeds 50 AMP.
enblethen
Moses Lake, WA
Posted: 07/31/20 07:50am Link  |  Quote  |  Print  |  Notify Moderator
Rig could potentially draw 100 amps over both legs. The rig should be wired to put less then 50 amps on each leg. The system is design with load calculations done at 120/240 volts.
Old campgrounds in some cases do not have a properly wired 120/249 volt system. They modified a 120 volt system by connecting both terminals to the same leg. This can overload and can cause damage to the neutral conductor in the shore power cord assembly.
The 50 amp 120/240 circuit breaker could trip if voltage drops increasing amperage.
Calculations followed by true amperage readings is the only way to know for sure.
Some larger rigs have power center that can tell what amperage is being drawn.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Charlie D.
E. Texas-Orange
Posted: 07/31/20 08:17am Link  |  Quote  |  Print  |  Notify Moderator
Would not the AC be divided and not all on one leg?
Enjoying Your Freedom?
Thank A Veteran
Native Texan
2013 Prime Time Crusader 330MKS
2018 Chevy 2500 D/A Z71 4x4 Offroad
2006 Holiday Rambler Savoy 33SKT-40,000 trouble free miles-retired
2006 Chevy 2500 D/A-retired
2013 Chevy 2500 D/A-retired
BB_TX
McKinney, Texas
Posted: 07/31/20 08:18am Link  |  Quote  |  Print  |  Notify Moderator
I would not be surprised at all if some of the large very high end MHs with 3 A/Cs and mostly all electric for everything else could easily pull over 100 amps and exceed the 240vac/50 amp park supply. 3 A/Cs, larger microwaves, induction cooktops, residential fridge, freezers, multiple TVs, high end home theater systems, washer/dryer, etc. along with all the other more common electrical features and that is a lot of power.
I would believe the park electrician.
wapiticountry
Mountain West
Posted: 07/31/20 08:25am Link  |  Quote  |  Print  |  Notify Moderator
Or perhaps the park electrician was attempting to explain why a 50 amp breaker was tripping and he didn't use exactly correct grammar. It is entirely possible for large rigs to have appliances and systems that would draw over 50 amps if all the appliances were operating at the same time and the breakers (either the park's or the coach's main) did not trip. Saying that those rigs can draw more than 50 amps is entirely correct. However, if the breakers are working correctly the coach cannot draw more than 50 amps for more than a few seconds. (subject to the tolerances allowed in manufacture and the delays built into the specifications of the breaker). The campground electrician was probably correct in what he was attempting to communicate, even if his verbiage was less than 100% accurate.
time2roll
Posted: 07/31/20 08:26am Link  |  Quote  |  Print  |  Notify Moderator
12,000 watts sure. 100 amps on any wire would trip the breaker.
Otherwise you may as well talk in battery power and say it pulls 1000 amps [emoticon]
675w Solar pictures back up
Lynnmor
Red Lion
Posted: 07/31/20 08:56am Link  |  Quote  |  Print  |  Notify Moderator
Of course, but there will be at least two on one leg.
pianotuna
Regina, SK, Canada
Posted: 07/31/20 09:09am Link  |  Quote  |  Print  |  Notify Moderator
Ask what conditions are necessary to cause a breaker to trip.
There are two ways for breakers to trip. One is thermal where the heat build up from running near or at full capacity for some time causes the trip. The other is a "magnetic" trip where the amp rating is exceeded for a time. We don't want nuisance trips from, for example, start up surge from the air conditioner.
So yes, for brief periods of time, a 50 amp service may exceed the rated values.
Regards, Don
Page of 11
