RV.Net Open Roads Forum: Tech Issues: Pulling more than 50 amps ?
 > Pulling more than 50 amps ?
Page of 11
TechWriter
On The Road
Posted: 07/30/20 08:32pm Link  |  Quote  |  Print  |  Notify Moderator
Our park electrician says that some of the big rigs with 3 ACs and electric everything can sometimes draw more than 50A from a 50A pedestal.
Truth or BS?
2001 Newmar Mountain Aire 4095 DP
Full Timer since May 2013
www.rvSeniorMoments.com
DISH TV for RVs
enblethen
Moses Lake, WA
Posted: 07/30/20 08:37pm Link  |  Quote  |  Print  |  Notify Moderator
Wired properly, BS!
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
fcooper
St. Augustine, Florida
Posted: 07/30/20 08:50pm Link  |  Quote  |  Print  |  Notify Moderator
100 amps available....50 amps per leg x 2 legs...so answer is yes
Fred & Vicki
rk911
DuPage County
Posted: 07/30/20 08:51pm Link  |  Quote  |  Print  |  Notify Moderator
i've heard of but not seen in person RVs with 100-amp service. connected to a 50-amp post i believe the most a rig like thar could draw would be a bit less than 50-amps else the post CB would trip.
Rich
Ham Radio, Sport Pilot
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
mobeewan
Hampton, Va
Posted: 07/30/20 09:17pm Link  |  Quote  |  Print  |  Notify Moderator
fcooper is right. You are not thinking about how a 50 amp / 240 Volt system works.
You have 2 120 volt legs with 50 amps available on each leg not 25 amps on each leg. 50 + 50 =100 amps of 120 volt power.
time2roll
Posted: 07/30/20 09:19pm Link  |  Quote  |  Print  |  Notify Moderator
Three? Each is maybe 16 max so even 4 would pull only 32 per side max.
Licensed electrician or handy man?
675w Solar pictures back up
mtofell1
Oregon
Posted: 07/30/20 09:57pm Link  |  Quote  |  Print  |  Notify Moderator
Stating an amperage without specifying the voltage is really only describing part of the story. More than 50A @ 120V? Sure. More than 50A @ 240V? Sure... for a few seconds until the breaker pops.
Honestly, RV power is listed in kind of a messed up way and it rarely gets clarified. A 30A hookup is 120V. A 50A hookup is 240V. So, if you just want a linear scale for comparison sake, a 30A hookup is 30, a 50A hookup is 100.
Mont G&J
Missoula, MT
Posted: 07/30/20 10:41pm Link  |  Quote  |  Print  |  Notify Moderator
Park electrician is correct.
pianotuna
Regina, SK, Canada
Posted: 07/30/20 11:01pm Link  |  Quote  |  Print  |  Notify Moderator
Add up all the possible loads. Neither leg will exceed 50 amps I suspect--but there are 2 legs.
In winter I can draw more than 50 amps--but it is shared over both legs.
Regards, Don
MEXICOWANDERER
las peƱas, michoacan, mexico
Posted: 07/30/20 11:05pm Link  |  Quote  |  Print  |  Notify Moderator
Electrical must always be designed for worst case.
Aside from water heater, reefer and battery recharging it is quite possible for a park power blip to knock all A/C off line. Then all of them may attempt a high head re-start. If the park is nearly full, the park becomes an involuntary appliance durability tester.
Page of 11
