RV.Net Open Roads Forum: Towing: Up sized my W.D. Bars
Search only in Towing
Open Roads Forum  >  Towing
 > Up sized my W.D. Bars
Vintage465
Prunedale CA.
Posted: 07/30/20 09:56pm Link  |  Quote  |  Print  |  Notify Moderator
I've got a Creek Side(Outdoors RV Mfg.)20fq. Tongue weight is 1200 pounds, trailer weight is 6700 pounds. 2013 Duramax 2500HD. Been using 1000 pound bars and I always thought there was a little too much bounce when I'd come to a Whoop-de-do in the highway. Upgraded the shocks to a set of Bilstiens and that help some but never got me to what I thought it should be. There was only so much tilt I could get out of the head to pre-load the springs.....so I upped to a new Reese Trunnion unit with 1200 pound bars and the head is very adjustable from a tilt perspective. After some tilt adjustments I got this dude down and the ride is great and the bounce is gone other than what you'd expect when encountering un-even road crossings, bridges that were never even in the first place and worse now after 10 repaving jobs! I actually think if I could've got a little more tilt in the head of the original one I could have got it, but this did fix it.............for about $500.00 that is!
V-465
2013 GMC 2500HD Duramax Denali. 2015 CreekSide 20fq w/450 watts solar and 465 amp/hour of batteries. Retiring in 2021, then look-out road, here we come!
dodge guy
Bartlett IL
Posted: 07/30/20 10:56pm Link  |  Quote  |  Print  |  Notify Moderator
I e always said that you can buy all e 1 ton dually you can buy, but if the hitch isnt setup properly then you will not be happy
. Glad you got it all figured out!
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
near Bishop, California
Posted: 07/31/20 08:20am Link  |  Quote  |  Print  |  Notify Moderator
Five hundred here, five hundred there. It’s all relative!
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-parallel & MPPT, Trojan T-125s. TALL flag pole. Prefer USFS, COE, BLM, NPS, TVA, state & county camps. Bicyclist! 14 year Army vet-11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
mbopp
Henrietta, NY, USA
Posted: 08/01/20 08:07am Link  |  Quote  |  Print  |  Notify Moderator
I see trunnion hitches fairly often in Facebook Marketplace.
2017 Grand Design Imagine 2650RK
2019 F250 XLT Supercab
Just DW & me......
campigloo
Baton Rouge, La
Posted: 08/01/20 09:12am Link  |  Quote  |  Print  |  Notify Moderator
Something else you might look into are stable loads. They engage the overload springs and are very easy to disengage when you’re not towing. They aren’t real expensive but unless you have a shop with a lift I wouldn’t recommend trying to drill the springs yourself. I tried that on mine and never got the first hole drilled. If you’re lucky and the spring is predrilled they’re easy to install.
mordecai81
United States
Posted: 08/03/20 07:25pm Link  |  Quote  |  Print  |  Notify Moderator
I've got 1200 lb bars on my Equalizer and have been happy with the towing experience with my rig - ORV 20FQ and 2014 F150. My tongue weight was 1150 lbs last time I weighed loaded for a long trip. I had originally intended to order the 1k bars when we bought the trailer but ordered the 1200lb by mistake. That mistake probably saved me 500 smackers. I guess the universe had to even out, somehow. These ORVs are tongue heavy, ain't they?
