RV.Net Open Roads Forum: Class C Motorhomes: Peeling out
Open Roads Forum  >  Class C Motorhomes  >  B+
 > Peeling out
Coelacanth
Syracuse, NY
Posted: 07/31/20 04:38am Link  |  Quote  |  Print  |  Notify Moderator
Folks,
I recently obtained a 2012 Holiday Rambler, Augusta from an estate sale. It was almost never used and has 7,500K on the odometer. Needs new tires, but that’s about it. It looks like new with one exception. The brow over the cab seems to be peeling. While scrubbing the roof yesterday, prior to applying a new coat of sealant to the seams, I noticed that the area above the cab is gradually losing a thin clear film. Is this some kind of clear coat? Or, is it part of the Holiday Rambler front graphic? I know HR was bought out by Monaco, and that this model is almost an orphan. But, I’d like to fix this if possible. Any hints are more than welcome.
bobndot
Posted: 07/31/20 08:44am Link  |  Quote  |  Print  |  Notify Moderator
Personally, I would get a professional opinion from a good body shop who knows fiberglass.
As far as I know gelcoat delamination is a common problem with many brands of rvs . I'm not sure if its a good idea to tackle a large area yourself if its a first time deal for you.
I know that body shops have performed the task of repainting. If that's the case with your rv then you will need a 'dust free paint booth' inside a garage to work.
The rv would need to be taped and wrapped in plastic to protect it from overspray. Surface prep, I would imagine, would be very important to be performed correctly. If that step is not done right then all your work will not last and need to be done over by a professional shop.
bdpreece
Yuma Arizona / Oregon Traveler
Posted: 07/31/20 11:12am Link  |  Quote  |  Print  |  Notify Moderator
Your clear coat finish is pealing off. Not an uncommon problem. I had mine re done last year.
Brian, Loretta & Daisy (Golden Retriever)
2008 Holiday Rambler Endeavor PDQ40
2014 Ford Explorer toad
Coelacanth
Syracuse, NY
Posted: 07/31/20 11:32am Link  |  Quote  |  Print  |  Notify Moderator
My thanks to both of you.
I’ll need to find a body shop in the area that will tackle it.
Any rough idea of the cost?
Bird Freak
Dallas Ga.
Posted: 07/31/20 05:57pm Link  |  Quote  |  Print  |  Notify Moderator
Only a body shop can tell you cost.
Eddie
03 Fleetwood Pride, 36-5L
04 Ford F-250 Superduty
15K Pullrite Superglide
Old coach 04 Pace Arrow 37C with brakes sometimes.
Owner- The Toy Shop-
Auto Restoration and Customs 32 years. Retired by a stroke!
We love 56 T-Birds
bobndot
Posted: 08/01/20 01:52am Link  |  Quote  |  Print  |  Notify Moderator
May as well start close to home, give Northside a call.
https://northsidecollision.com/
Northside does RV body work
Coelacanth
Syracuse, NY
Posted: 08/01/20 10:57am Link  |  Quote  |  Print  |  Notify Moderator
Thanks a bunch. I will.
You have used them?
bobndot
Posted: 08/01/20 11:35am Link  |  Quote  |  Print  |  Notify Moderator
No. I have heard the name and remember that shop being a long time family business when i was a Pulaski-Boylston member riding up on Tug Hill.
Because of the good reviews and nearby location I just offered it as starting point to see if your in the $2,000 range or $10,000 range.
The shop is an rv shop so it has tall doors and large bays to accept rvs
Coelacanth
Syracuse, NY
Posted: 08/01/20 01:30pm Link  |  Quote  |  Print  |  Notify Moderator
I’ll give them a shout.
All I need is the brow above the cab redone. Everything else is like new.
 > Peeling out
