RV.Net Open Roads Forum: Tech Issues: Low Voltage on One 50A Leg
 > Low Voltage on One 50A Leg
Bumpyroad
Virginia
Posted: 07/31/20 04:20pm Link  |  Quote  |  Print  |  Notify Moderator
camperdave wrote:
so as a 30a RVer, sounds like it may be worth carrying two 50a - 30a adapters, one for each line. Pick the one with the higher voltage. Anyone do that instead of plugging into the 30a receptacle?
at one time I was going to take my continuity tester to the RV stores and test the 30/50 amp pigtails to see if I could find two that were different but thought better of it. [emoticon]
you could of course make your own adapter.
bumpy
pianotuna
Regina, SK, Canada
Posted: 07/31/20 04:39pm Link  |  Quote  |  Print  |  Notify Moderator
Camperdave,
You would have to "roll your own". If going that far--why not build a "break out box" so you could have twin 30 amp outlets, one for each "leg". I added breakers to my "box" as well.
* This post was edited 07/31/20 05:35pm by pianotuna *
Regards, Don
Wherever I happen to park
Posted: 07/31/20 04:51pm Link  |  Quote  |  Print  |  Notify Moderator
Generally this idicates a weak Neutral but it can happen that almost all the park is on one leg (the low one) YOu need multiple voltage meausurements
The Park outlet (Sadly it's hard to measure when plugged in but if the box has 20-3--50 measure the 20 and 30 (use a puck style adapter on the 30 and a plug in meter) as these are usually on different legs (not always)
The park distribution box is also a test point but .... for the park not you.
Home is where I park it.
CA Traveler
The Western States
Posted: 07/31/20 04:52pm Link  |  Quote  |  Print  |  Notify Moderator
It's common practice to use a 50/30 adapter for 30A RVs for better voltage.
However voltage continues to vary and a autoformer would be a better option.
2014 Grand Cherokee Overland
Bob
DrewE
Vermont
Posted: 07/31/20 06:56pm Link  |  Quote  |  Print  |  Notify Moderator
Gdetrailer wrote:
I suspect what the OP is seeing is an issue in the campgrounds electrical system coming from MORE 30A 120V usage..
Most pedestals will by default have the 30A 120V outlet on the SAME "Line" and most likely that default IS L1, and more folks will be hooked up to the 30A outlets..
Hence the reason OP is seeing the voltage mismatch..
Given that the pedestals would presumably all be wired identically, it would be very odd for a campground not to wire up half the pedestals in the loop with the two legs swapped from the other half of the pedestals, such that the 30A sockets would tend to balance each other out. There's nothing other than an arbitrarily chosen convention that makes one particular leg L1 rather than L0, after all.
Roger10378
Goodrich, MI.
Posted: 07/31/20 07:12pm Link  |  Quote  |  Print  |  Notify Moderator
OP states "in several campgrounds" so that makes it most likely the problem is in his unit. The fact that the higher number is close to nominal says there is something wrong on the side with the low number. I would be looking for a loose connection somewhere in the positive side.
2005 Cardinal 30TS
2007 Chevy 2500HD D/A
beemerphile1
Ohio
Posted: 07/31/20 07:19pm Link  |  Quote  |  Print  |  Notify Moderator
Test your unit. Use an adapter to connect to a 30a service. Voltage on L1 and L2 should be identical, is it? If not, your unit might be adjustable.
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
Acampingwewillgo
Posted: 07/31/20 09:00pm Link  |  Quote  |  Print  |  Notify Moderator
Since I've had erratic measurements a time of two, check both ends of your cord set ....mine had a loose neutral connection on my female Marinco 50 amp plug. A loose connection which soon turned into a burnt connection resulting in no power to RV. A quick trip to pick up a new female and all was well with the world.
96 Vogue Prima Vista
The Kid's: Humphrie, the Mini Schnauzer and Georgie,wire haired dachshund, Senior Cavalier Rosie and Potter
Rainbow Bridge: Laddie,Scoutie,Katie,Cooper,Kodie,Rubie,Maggie, Cassie and Mollie, Elvis Love You!
Rally's and get togethers-Lots
Bumpyroad
Virginia
Posted: 08/01/20 07:02am Link  |  Quote  |  Print  |  Notify Moderator
sounds about right.
bumpy
joelc
Cedar Point, NC
Posted: 08/01/20 09:12am Link  |  Quote  |  Print  |  Notify Moderator
Are you reading this at the post or do you have a built in voltage EMS inside your coach? As noted above you need the raw voltage without load. A few volts difference will not matter.
