RV.Net Open Roads Forum: Tech Issues: Low Voltage on One 50A Leg
 > Low Voltage on One 50A Leg
Acampingwewillgo
Posted: 08/01/20 11:09am Link  |  Quote  |  Print  |  Notify Moderator
Bumpyroad wrote:
Acampingwewillgo wrote:
. A quick trip to pick up a new female and all was well with the world.
sounds about right.
bumpy
If only that was so easy!!!
I had to chuckle after reading it again:-)
96 Vogue Prima Vista
The Kid's: Humphrie, the Mini Schnauzer and Georgie,wire haired dachshund, Senior Cavalier Rosie and Potter
Rainbow Bridge: Laddie,Scoutie,Katie,Cooper,Kodie,Rubie,Maggie, Cassie and Mollie, Elvis Love You!
Rally's and get togethers-Lots
TechWriter
On The Road
Posted: 08/01/20 02:10pm Link  |  Quote  |  Print  |  Notify Moderator
time2roll wrote:
Poor connection or unbalanced load. If this is at the pedestal you will need the park to fix it or move or use your voltage booster.
Yep, it's at the pedestal. One leg goes low about 1 pm daily when all the ACs are on. Yep, I use a voltage booster.
2001 Newmar Mountain Aire 4095 DP
Full Timer since May 2013
www.rvSeniorMoments.com
DISH TV for RVs
Wherever I happen to park
Posted: 08/01/20 04:04pm Link  |  Quote  |  Print  |  Notify Moderator
DrewE wrote:
Gdetrailer wrote:
Hence the reason OP is seeing the voltage mismatch..
Given that the pedestals would presumably all be wired identically, it would be very odd for a campground not to wire up half the pedestals in the loop with the two legs swapped from the other half of the pedestals, such that the 30A sockets would tend to balance each other out. There's nothing other than an arbitrarily chosen convention that makes one particular leg L1 rather than L0, after all.
Sense that makes however......
Have observed a park re-wiring several sites. Even lent a hand (Steading the posts while the park paid employee, a friend, shoveled dirt around it and tamped it down)
They ran a bunch of BLACK wires.. Now they kept track of N and G but the two hots were both black. all black. no way to tell 1 from 2 at the box. So it is likely some 30's are L1 and others l2
But it's possible all one or the other.
And in another park (two others actually) have observed electricians working on them. again both L's were black. And Black is Black (I want my baby bac... Opps that's a song)
Home is where I park it.
time2roll
Posted: 08/01/20 04:10pm Link  |  Quote  |  Print  |  Notify Moderator
Good to go, no worries.
675w Solar pictures back up
