RV.Net Open Roads Forum: Can AUTO mode damage A/C from frequent shutdowns?
 > Can AUTO mode damage A/C from frequent shutdowns?
Cummins12V98
on the road
Posted: 08/01/20 09:08am Link  |  Quote  |  Print  |  Notify Moderator
Fan in the on position is good because the air is constantly moving and not having to cool down the ducts when kicking on. I leave my fan in the ON position it gives more even temps.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
dougrainer
Carrolton, Texas
Posted: 08/01/20 09:43am Link  |  Quote  |  Print  |  Notify Moderator
cavie wrote:
3 tons wrote:
Perhaps member Doug can enlighten us a bit more, but from what I know about my Coleman Mach 1, regardless of the fan mode, etc. once the compressor cycles to Off there is a 3 min time delay before the compressor can restart again, this to allow time for the high-side of the compressor to equalize (or bleed down) to the low-side, however can’t say whether this attribute is driven by the air conditioner or by the t-stat...
3 tons
the time delay starts when the uni has been TURNED OFF. it will not try to cycle it's self in just 3 min. if you turn it off or the power goes out it will not restart for ten min. not 3.
Where do you get this 10 minute delay? I constantly in service shut power OFF or turn the AC OFF and never have had a 10 minute delay. Doug
From Dometic.
. Compressor Time Delay
A time delay of approximately 2 minutes occurs any time the compressor is required
to begin the cooling or heat pump cycle.
* This post was edited 08/01/20 09:55am by dougrainer *
dougrainer
Carrolton, Texas
Posted: 08/01/20 09:49am Link  |  Quote  |  Print  |  Notify Moderator
kellem wrote:
Perhaps I misunderstand but never heard of AC adjusting fan speed on its own.
Ours is as follows.
High constant
Low constant
Auto high
Auto low.
Depends on the system. Dometic, on AUTO, the AC compressor is ON and if more than 5 degrees diff, the HI fan will come on. Once the AC gets closer or less than that 5 degree, the Fan will "shut" of for a second and then restart on LOW and once temp is reached will shut both Compressor OFF and the Fan OFF. From your desciption, you have a RVP(Coleman) wall tstat. And yours operates as you state. This is for the LCD Coleman tstat. Doug
Set Fan Speed for Cooling Mode
1. Place the slide switch in the COOL position.
2. Pressing the MODE button will toggle through the available speeds.
• “COOL AUTO” setting allows the speed to vary depending on the cooling needs which
is the default setting.
• “COOL HIGH” or “COOL LOW” setting will set the fan speed to run continuously at high
or low, but the upper unit will cycle when cooling is needed.
• “FAN HIGH” and “FAN LOW” setting will set the fan to run continuously at high or low
speed. The upper unit will not run to produce cooling. Setpoint is not adjustable in this
mode.
dougrainer
Carrolton, Texas
Posted: 08/01/20 09:53am Link  |  Quote  |  Print  |  Notify Moderator
This is for Dometic that have 3 speed fan. Doug
A. Auto Fan
When “AUTO” fan is selected, the fan speed will vary depending on the difference
between the temperature set-point and the room temperature. In “AUTO” fan, the
compressor and fan will cycle ON and OFF with the thermostat.
When the difference is:
8 °F / °C or more The fan operates on HIGH
5 to 7 °F / °C The fan operates on MED
4 °F / °C or less The fan operates on LOW
