RV.Net Open Roads Forum: Class A Motorhomes: HWH Oil Tank QUestion
 > HWH Oil Tank QUestion
Old Snipe
Full Timer
Posted: 07/31/20 12:18pm Link  |  Quote  |  Print  |  Notify Moderator
On my 07 WB Journey I need to check the oil level in my HWH tank. The cap is tight and before I break something I need to know if it is a twist off cap or a pull off cap. It appears to be plastic and I dont' want to make a problem by removing it wrong.
Thanks!
Paul D
2007 Winnebago Journey 39K, Cat C7 350 HP
(aka "R SANITY")
2003 Honda Element 4WD Toad
www.rsanityrvtravels.blogspot.com
MountainAir05
New Mexico
Posted: 07/31/20 02:25pm Link  |  Quote  |  Print  |  Notify Moderator
On ours it screws off. Look below the plastic part which is a vent and feel , should be a space for a 7/16 or 1/2 inch open end wrench to slide below it and onto a fitting and turn counter clock. That is how ours is. Post back and hopefully someone with the same Model as your will have more info.
Just found this , not sure you have the newer tank system. But still screws off.
http://www.hwhcorp.com/mi16_02_oillev.html
dougrainer
Carrolton, Texas
Posted: 07/31/20 02:49pm Link  |  Quote  |  Print  |  Notify Moderator
ALL HWH tank filler caps screw in and out. Doug
Old Snipe
Full Timer
Posted: 07/31/20 05:34pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the replies. I thought it screwed off but I didn't want to force it and "screw" it up!
Best Regards!
dougrainer
Carrolton, Texas
Posted: 07/31/20 05:50pm Link  |  Quote  |  Print  |  Notify Moderator
FYI, The white Plastic filler caps have a built in 1/4 inch socket to open the solenoid bypass valve screws. Doug
