RV.Net Open Roads Forum: Refrigerator left running with doors open for 2 weeks !
 > Refrigerator left running with doors open for 2 weeks !
mginnetty
Berlin, NH
Posted: 07/31/20 04:56pm Link  |  Quote  |  Print  |  Notify Moderator
Had kids playing in the RV when it was out in the driveway ready to be put into storage with the fridge/freezer doors propped open with door clips. I'm guessing one the kids was pushing buttons and turned on the fridge and I just noticed it now 2 weeks later [emoticon]
The fridge and freezer weren't cool at all and had about an inch of water pooled in the bottom and some in the trays on the door. I turned off the power and have cleaned up the water and hope that it doesn't need replacement.
Anyone have an experience with fridge problems like this ?
Thanks for the info.
-Mark...
Mfan
Otsego,Mi
Posted: 07/31/20 05:10pm Link  |  Quote  |  Print  |  Notify Moderator
Have you tried to turn it on and cool it now? What type?
pianotuna
Regina, SK, Canada
Posted: 07/31/20 05:42pm Link  |  Quote  |  Print  |  Notify Moderator
Mark how close to level was the fridge?
Regards, Don
dougrainer
Carrolton, Texas
Posted: 07/31/20 05:53pm Link  |  Quote  |  Print  |  Notify Moderator
Unless you have a odor. Running with the doors open will not cause a problem. UNLESS as another stated, you stored the unit off level more than 3 to 5 degrees. Doug
Mono Basin National Forest Scenic Area
Posted: 07/31/20 06:02pm Link  |  Quote  |  Print  |  Notify Moderator
Use a solar system to keep your batteries charged. Unplug from shore power. Install a master switch and turn it off.
DrewE
Vermont
Posted: 07/31/20 06:21pm Link  |  Quote  |  Print  |  Notify Moderator
The water that collected is good evidence that the fridge was working properly--the cooling unit caused it to condense and collect. (It also suggests that the drip pan or its drain tube may possibly not be arranged properly or might be plugged up, assuming your fridge has them.) I don't think you have anything to worry about.
Incidentally, 3 degrees off of level is a quite obvious slope, around a 5% grade.
wopachop
lb
Posted: 07/31/20 06:53pm Link  |  Quote  |  Print  |  Notify Moderator
Let's say you're in the trailer looking at the fridge door. Which angle hurts it the most?
pianotuna
Regina, SK, Canada
Posted: 07/31/20 06:55pm Link  |  Quote  |  Print  |  Notify Moderator
wopachop,
Direction of travel 3%. (1/2 bubble)
Driver to front seat passenger 5%. (less that 1 bubble)
I hope that helps.
beemerphile1
Ohio
Posted: 07/31/20 07:23pm Link  |  Quote  |  Print  |  Notify Moderator
Did that to myself once. Had water inside the refrigerator and on the floor of the trailer. Didn't do any damage.
Clean up the mess and check, is it okay now?
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
Bert the Welder
Van. Island
Posted: 08/01/20 01:45pm Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
wopachop,
I hope that helps.
Thanks for this PT. Had wondered how much slope front to back and side to side would be in the "OK" range. Just never remembered to ask....[emoticon]
"> 1998 GMC 2500, 10.5 Okanagan, My better/smarter half, George and Finnegan(APBT), all I need.
