RV.Net Open Roads Forum: Tech Issues: RV kitchen sink
 > RV kitchen sink
GDesign366Den
California
Posted: 07/31/20 10:46pm Link  |  Quote  |  Print  |  Notify Moderator
Our kitchen sink stopped draining so I suspected vapor lock so I unscrewed the in line valve the water dropped out of the sink and sat in the pipe. It still would not go the rest of the way down. Ran a 15’ snake down the pipe and no obstructions. Have taken apart the p trap to make sure no clog but still no luck. We have used a plunger with no success we also used a drop in clog remover but no luck. We have the grey tank open water flows out so I know that isn’t the issue. Hoping someone has an idea.
Sea Six
Posted: 08/01/20 01:30am Link  |  Quote  |  Print  |  Notify Moderator
Is the gray tank full?
dougrainer
Carrolton, Texas
Posted: 08/01/20 04:04am Link  |  Quote  |  Print  |  Notify Moderator
AGE Make and Model of RV will help. Doug
Bill.Satellite
Full-timer
Posted: 08/01/20 05:45am Link  |  Quote  |  Print  |  Notify Moderator
You speak of a valve and not a P-trap. If you don't have a P-trap you would have a duck bill sort of valve and using any of the devices you describe could cause the valve "bill" to fold up over itself and prevent water from flowing.
What I post is my 2 cents and nothing more. Please don't read anything into my post that's not there. If you disagree, that's OK.
Can't we all just get along?
Bobbo
Wherever I park
Posted: 08/01/20 07:40am Link  |  Quote  |  Print  |  Notify Moderator
Is water backed up into the shower pan?
A. yes - your waste tank is full
B. no - most likely Bill.Satellite is right and you have a bad valve of some kind under the sink.
Bobbo and Lin
Lantley
Ellicott City, Maryland
Posted: 08/01/20 07:58am Link  |  Quote  |  Print  |  Notify Moderator
How many grey tanks do you have? There maybe more than 1.
2019 Duramax w/hips,2012 Open Range,Titan Disc Brake
H-head TPMS,BD3,RV safepower,17" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps
Correct Trax,Splendide
ajriding
st clair
Posted: 08/01/20 09:20am Link  |  Quote  |  Print  |  Notify Moderator
Do you have a P-trap or another type of trap under the sink, like a "concession trailer" trap?
Does the water eventually slowly drain out or does it stay?
Your in-line valve is one of those one-way valves under the counter to let air into the pipe, but not out, common valves in houses and RVs...
Sounds like the issues is after the "in-line" valve. Even though your snake made it through you could still have a blockage that just filled back in after the snake was removed. Try snake again and really work it and spin it in every section.
The valve others are talking about is unfamiliar to me so that could be it too, I cant help there.
Try a garden hose with trigger nozzle, spray water down the drain and this might do more than the plunger did. Risky, but it might dislodge anything. keep a hand or a towel over top so nothing sprays back in your face. use short quick burst of spray at a time.
Wherever I happen to park
Posted: 08/01/20 04:11pm Link  |  Quote  |  Print  |  Notify Moderator
I have both "Gray" and "Wash" on my rig (In addition to black)
Wash water is shower bathroom lavs and I suspect cloths washer if I had one.
Gray is above with the addition of Kitchen Sink or Dishwasher in case you wonder about definitions.. Yes there is a legal difference but off topic here.
When My kitchen sink fails to drain. every time for the last 15years + it's been time to go out side and "Take a dump" (Tank was full).
A cogged pipe can also do it but I've not had that happen in longer than I recall.
Home is where I park it.
 > RV kitchen sink
