RV.Net Open Roads Forum: New to rv ownership is this an okay fix?
 > New to rv ownership is this an okay fix?
Astoria2020
Virginia
Posted: 08/01/20 12:20am Link  |  Quote  |  Print  |  Notify Moderator
I have owned my camper for two months. When my wife and I arrived at the camp ground I noticed the ceiling had a slow drip. 24 hours later it quit raing and I found the mushroom vent cover had blew off. The closest dealer was a 45 min drive and they just had the regular attic/sewer vents, so I bought that and some putty tape and lap sealent and bolted it to the base of the the old vent. So far No leaks. Should I try and find the right vent or leave it.
bucky
Raleigh metro
Posted: 08/01/20 03:36am Link  |  Quote  |  Print  |  Notify Moderator
I wouldn't have waited until the rain stopped. Too late for that now but get the right cover.
Water damage is the number one killer of RVs.
2005 Cummins 3500 2WD LB quad cab dually pulling a 2014 Blue Ridge 3025RL
midnightsadie
ohio
Posted: 08/01/20 04:58am Link  |  Quote  |  Print  |  Notify Moderator
double check that area for water damage , could be that cover has been missing for a long time.
MFL
Midwest
Posted: 08/01/20 05:26am Link  |  Quote  |  Print  |  Notify Moderator
Kind of hard to say if fix is okay, without seeing it. A pic would help, to better understand your description of the fix.
Jerry
Lone Pine, CA
Posted: 08/01/20 07:40am Link  |  Quote  |  Print  |  Notify Moderator
Temporary fixes are temporary. Repair properly before it rains again. You saw no additional water but that doesn’t mean it wasn’t still leaking.
Astoria2020
Virginia
Posted: 08/01/20 09:29am Link  |  Quote  |  Print  |  Notify Moderator
The rain cover was on before we left as I had just cleaned the roof and inspected all seems I'm so ocd as I even bout and installed max air vent covers for added protection.
GMH
Canada
Posted: 08/01/20 12:52pm Link  |  Quote  |  Print  |  Notify Moderator
Is this the vent you are talking about? Rain going down the pipe should not matter, as it will wind up in the grey or black tank. I filled the broken out chunk of the base On mine with silicone to seal it and then replaced the cap with one I found at Canadian Tire (Camco brand I think). It has two spring steel fingers that slide down inside the pipe to hold it in place.
