RV.Net Open Roads Forum: Towing: Shifting An Automatic when towing.
Search only in Towing
Open Roads Forum  >  Towing
 > Shifting An Automatic when towing.
mbopp
Henrietta, NY, USA
Posted: 08/01/20 08:06am Link  |  Quote  |  Print  |  Notify Moderator
Towing with my F250 6.2, I use tow-haul but lock out 6th gear because it hunts too much.
2017 Grand Design Imagine 2650RK
2019 F250 XLT Supercab
Just DW & me......
time2roll
Posted: 08/01/20 08:37am Link  |  Quote  |  Print  |  Notify Moderator
JustSomeOldDud wrote:
Greetings all. New tow-er here.
Does anyone have a link to some comprehensive yet easy to understand directions for manual shifting an automatic when towing.
I mean, im guessing that's why we have "L" option
Thanks in advance.
Would help to know what vehicle you are driving, engine, transmission speeds etc.
If your only options are D & L you may not have many options to manually shift. Or is L the low range on your transfer case?
Otherwise let the automatic do its thing unless it starts hunting gears up and down.
675w Solar pictures back up
Williams AZ area
Posted: 08/01/20 08:47am Link  |  Quote  |  Print  |  Notify Moderator
“I can do a hell of a better job of up and down shifting/down hill braking than the computer.“
Plus it’s more fun to do it manually.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-parallel & MPPT, Trojan T-125s. TALL flag pole. Prefer USFS, COE, BLM, NPS, TVA, state & county camps. Bicyclist! 14 year Army vet-11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
campigloo
Baton Rouge, La
Posted: 08/01/20 09:06am Link  |  Quote  |  Print  |  Notify Moderator
My tv is a 2500 Ram/Cummins. 95% of the time I let the computer do all the work. If I get on serious long grades I will sometimes use the manual to hold the speed and rpm to what I want for climbing or descending. If you have most any kind of later model vehicle it will take care of it. Put it in t/h and go.
Cummins12V98
on the road
Posted: 08/01/20 09:10am Link  |  Quote  |  Print  |  Notify Moderator
MFL wrote:
Welcome to the forum. You don't say what tow vehicle you have. When asking a question about your vehicle, a complete description of it would help to get more accurate answers.
Jerry
Now don't you think you're getting a bit picky asking for info to give an accurate answer???
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Cummins12V98
on the road
Posted: 08/01/20 09:11am Link  |  Quote  |  Print  |  Notify Moderator
Transmissions can't see the big grade ahead. Best to drop a gear before hitting the grade.
kellem
Shenandoah valley,VA
Posted: 08/01/20 09:23am Link  |  Quote  |  Print  |  Notify Moderator
Towing in the mountains of WV, I've often manually shifted my autos but never yanking down to low at speeds.....common sense goes a long ways.
rexlion
Broken Arrow OK
Posted: 08/01/20 09:40am Link  |  Quote  |  Print  |  Notify Moderator
One thing to know is that your max HP and torque will be at a relatively high rpm, like maybe 5000, on non-turbo gas engines. A lot of the 4, 5, and 6 speed trannys have an overdrive gear that lets the engine lope along at about 2000 rpm. A hill will cause the torque converter to unlock, and the engine will gain about 500 rpm and some HP and torque. A steep enough hill will make the trans shift down and the gain will be more like 1000 rpm or so... again, more HP and torque are supplied. But when you tow a trailer, that torque converter unlocks much too frequently, causing friction and heat buildup that can damage the transmission. Therefore, people lock out overdrive (via a lockout button on some models, tow-haul mode on others, and still others by moving the shift lever). This prevents the torque converter from doing a bunch of unlocking-locking-unlocking.
Climbing a long, steep grade in the Rockies or someplace similar, shifting down even further can be advantageous for the extra HP and torque gain. Running at a slower speed but at 4000-5000 rpm is easier on the drive train. And when descending, always downshift similarly so the engine helps hold you back and you don't have to hit the brakes as often. Never ride the brakes down the hill, they'll overheat and you may become a runaway!
Mike G.
Liberty is meaningless where the right to utter one's thoughts and opinions has ceased to exist. That, of all rights, is the dread of tyrants. --Frederick Douglass
photo: Yosemite Valley view from Taft Point
ssthrd
Vancouver Island
Posted: 08/01/20 12:05pm Link  |  Quote  |  Print  |  Notify Moderator
X2. Just before going up or just before going down.
2014 Laredo 292RL
2018 GMC 3500HD 6.5' box SRW Denali Duramax
DeeBee, JayBee, and Jed the Black Lab
ppine
Northern Nevada
Posted: 08/01/20 12:59pm Link  |  Quote  |  Print  |  Notify Moderator
I was going over Sonora Pass last week. Trailers are discouraged. There was one section that was 26% and I was in first gear with my one ton Ford. I shift into second once in awhile on steep sections. First gear is unusual but it was very handy when the roads are that steep.
