RV.Net Open Roads Forum: The Way “All” 5th Wheels Frames Should Be Built
 > The Way “All” 5th Wheels Frames Should Be Built
memtb
Wyoming
Posted: 08/01/20 03:05pm Link  |  Quote  |  Print  |  Notify Moderator
Many folks don’t think about or have any knowledge about the most important part of the RV..... mainly because it is mostly unseen. The frame and suspension is the foundation for your RV. There are places where costs can be reduced, the frame design and integrity .....is not it!
Obviously the beam dimensions (wall thickness, height, etc) can be reduced for a smaller, lighter unit.....but this is not the place to put the minimum!
If nothing else.....it may give folks an idea of things to look for when shopping for your next RV!
And no, we don’t own one! However, many of the features mentioned are things we’ve had in our 5th wheels since the ‘90’s! memtb
https://m.youtube.com/watch?v=2fKbAUuwgPo
* This post was last edited 08/01/20 03:31pm by memtb *   View edit history
Todd & Marianne
Miniature Schnauzer's - Sundai, Nellie & Maggie Mae
2007 Dodge Ram 3500, 6.7 Cummins, 6 speed manual, 3.73 ratio, 4x4
2004 Teton Grand Freedom, 39'
2007 Bigfoot 30MH26Sl
TXiceman
Full Time RVer
Posted: 08/01/20 04:34pm Link  |  Quote  |  Print  |  Notify Moderator
This why I love my HitchHiker Champagne. Heavier Young's Welding frame and Mor/Ryde IS suspension with HD brakes.
Yes we are heavy...19,500 lb on the road with no water.
Ken
Amateur Radio Operator.
goducks10
There
Posted: 08/01/20 05:17pm Link  |  Quote  |  Print  |  Notify Moderator
Link
https://www.youtube.com/watch?v=2fKbAUuwgPo&app=desktop
One of the main reasons we bought our Northwoods RV 5er 8 years ago and last year bought an Outdoors RV TT. Both in house made frames.
While not of the same caliber as the one in the video, they're still well built with very few issues.
memtb
Wyoming
Posted: 08/01/20 05:43pm Link  |  Quote  |  Print  |  Notify Moderator
If I were to get a “new” (unlikely) RV, Arctic Fox would be on the short list.....if I won a big lottery, New Horizons would be the “only” one on the list. Meanwhile, I hope that our old Teton will carry us to the end of our RV’ing days! memtb
SDcampowneroperator
South Dakota
Posted: 08/01/20 05:54pm Link  |  Quote  |  Print  |  Notify Moderator
There are MFGRs claims about frame strength that are not entirely true. Our Carriage 5er boasted 3/16 wall.(.188) 2x6 Turns out 3/16 was only used in the front portion, under the load over axle portion was 1/8 wall (.125)
Yes we bent the frame there while following their load recommendations because of a massive (unmarked construction bridge ) bump in the road. A spendy fix. It also tore out the rubber morryde equalizers
I belatedly determined the thinner wall tubing by the radius of the corners of the tubing. When rectangular tube is formed, the wall thickness creates a more square corner depending on wall thickness. It does not take an engineering degree to see the 50% increase in strength from the difference, or the maybe $20 in cost to them and the extra 50 # to make a frame that can take all the road may throw at it.
So look at the frame. If you see any portion that looks different, like squarer corners on tubular, or narrower or thinner flanges on I Beam frames. Question it. they are lighter, thinner than the more radiused corners of heavier tubing.
Veebyes
Posted: 08/01/20 06:45pm Link  |  Quote  |  Print  |  Notify Moderator
At RV shows or dealerships the first thing to be done is get on hands & knees & inspect frames, especially in spring hanger mounting areas.
2007 Alpenlite 34RLR
RickLight
Washington
Posted: 08/01/20 08:52pm Link  |  Quote  |  Print  |  Notify Moderator
Modern engineering has routinely made products stronger and lighter using less material.
Yes the frame is critical, but far more than wall thickness is required. The engineering however is only as good as the managers will allow and the warranty will support. Both are powered by money!
Rick,
2019 Grand Design Reflection 150 273MK
2015 Ford F350 CC SB Lariat Powerstroke
PullRite Superglide
memtb
Wyoming
Posted: 08/02/20 06:20am Link  |  Quote  |  Print  |  Notify Moderator
Rick, You are very correct about the engineering and then the manufacturers employing said engineering. The video (New Horizons) spent a little bit of time discussing bracing, gusseting, etc. not used on most RV frames.......as well as frame dimensions and wall thickness.
Ultimately, in comes down to the manufactures providing the best frames for our RV’s within reasonable costs! The sad reality is....the “bean counters” determine the quality of the product that is offered to the public. memtb
JIMNLIN
Oklahoma
Posted: 08/02/20 06:32am Link  |  Quote  |  Print  |  Notify Moderator
Looks like a good heavy built frame for that 43' unit.
I liked his point of their not using axles that have to much capacity for the job.
JTrac
Oklahoma
Posted: 08/02/20 08:01am Link  |  Quote  |  Print  |  Notify Moderator
A heavy, quality built fifth wheel is great for those who need them but that market is limited. I have nothing to back it up other than what I see in rv parks and on the road, but it appears most folks want something they can tow with a 3/4 or maybe a one ton single rear wheel truck. My guess is that's why Montana bragged for years about being the best selling fifth wheel and why manufacturers like Excel and Nuwa are gone. I think quality is possible with lighter weight units but it will cost more to do which makes them less competitive with those who don't.
JimT
2020 Jayco Pinnacle 32RLTS, 2020 Ford F350, Platinum, 6.7 diesel, 4X4, CCLB, SRW, 12,400 GVWR, 4562 payload capacity
