RV.Net Open Roads Forum: Newbie shopping - need advice on C vs small A
 > Newbie shopping - need advice on C vs small A
shalbleib71
Louisville, KY
Posted: 08/01/20 05:32pm Link  |  Quote  |  Print  |  Notify Moderator
So I'm looking for a potential full-time RV for one, maybe a pet eventually. I've been looking at C's pretty much exclusively (some B+s) but then I thought what about small A's?
Primary concerns for the decision would be:
- Gas mileage
- Service costs
- Drivability - I plan to boondock when possible and am aware that road conditions can be a bit more primitive.
Anything else I should be considering, and what's your recommendation? Any other pros and cons would be very beneficial.
Thx in advance!
SDcampowneroperator
South Dakota
Posted: 08/01/20 06:23pm Link  |  Quote  |  Print  |  Notify Moderator
Scott, it depends on many factors only you can answer when you look in the mirror. I hazard to guess that a shorter diesel A will give you the best bang and value over time. Fuel cost will be less with diesel over gas, that depends on mileage driven. Many do not drive more than a few k's / yr. The more miles, better to go diesel.
For dispersed camping you want high capacity tanks, batteries, a genny, maybe solar, Propane or Diesel powered heater and genny.
Also you have to consider your itinerary. To follow the seasons in prime areas camp fees will be higher.
A couple weeks dry camping at the Q (if you are new look that up as Quartzsite, Az.) soon teaches value of hookups unless you are a handy, proactive person.
Rv live is not cheap. It is freedom. it is a new sunrise or sunset wherever you decide to be that day.
DesertRatz
92276
Posted: 08/01/20 06:36pm Link  |  Quote  |  Print  |  Notify Moderator
Economics favor the smallest RV possible, I think. I recently bought a C. While looking, I looked at A's costing the same amount as I paid for the C. In the end, I reasoned that the RISK of a high cost repair was as lot higher on an A than on a C. Tires, brakes and transmissions will cost a lot more. I didn't want to find myself with an RV I couldn't afford to repair.
If I was going solo, I would need nothing more than a Poptop VW.
pianotuna
Regina, SK, Canada
Posted: 08/01/20 06:47pm Link  |  Quote  |  Print  |  Notify Moderator
Having owned both a diesel and gas Class C, I favor the gas.
A class A, given the same "footprint" as a C may nearly always have more storage. That is a big deal if you plan to full time.
It comes down to finding something in great condition.
Water leaks are the killers of any RV. Do not, under any circumstances, buy one where there is water damage. Pretty much anything else can be fixed, provided there are Chassis parts available.
Regards, Don
Mono Basin National Forest Scenic Area
Posted: 08/02/20 07:43am Link  |  Quote  |  Print  |  Notify Moderator
Have you rented an A, B and C to determine which you prefer?
theoldwizard1
SE MI
Posted: 08/02/20 09:34am Link  |  Quote  |  Print  |  Notify Moderator
- Gas mileage
- Service costs
You hit the nail on the head ! Class C wins in all cases.
A B+ (depending on whose definition of what a B+ is !) also wins 2 out of 3 (service will be about the same) over a Class C.
shalbleib71
Louisville, KY
Posted: 08/04/20 03:43pm Link  |  Quote  |  Print  |  Notify Moderator
I have rented a C for a week and liked it just fine. Might be a little trickier to find a small A for rent, but it's a good idea.
