RV.Net Open Roads Forum: RP fuses blowing when not on shore power
 > RP fuses blowing when not on shore power
1977tgregg
Posted: 08/01/20 07:00pm Link  |  Quote  |  Print  |  Notify Moderator
Hoping someone has some advice for me. I have a 1 year old Salem bunkhouse with a WF8955 power center. Was getting ready for a weekend trip and a few days before checked everything out for function and all was good. Went out the day before leaving to start the fridge and the RP fuses were blown. Replaced and had lights and fridge again. Went out the day we were to leave and the fuses were blown again. Attempted to replace and appears to be a dead short. Only used the camper one time and now just out of warranty. Any help is greatly appreciated. In a rush I did replace the entire power center but I found that I didn't troubleshoot properly and missed a step leading to misdiagnosis.
Bobbo
Wherever I park
Posted: 08/01/20 07:12pm Link  |  Quote  |  Print  |  Notify Moderator
Ummm, are the battery cables reversed? After all, they are Reverse Polarity fuses. (The cables can be reversed at either end. They can be reversed at the battery, or, they can be reversed at the converter/charger.)
Bobbo and Lin
1977tgregg
Posted: 08/01/20 07:15pm Link  |  Quote  |  Print  |  Notify Moderator
No. Everything worked fine then a couple days later its blowing fuses
time2roll
Posted: 08/01/20 07:26pm Link  |  Quote  |  Print  |  Notify Moderator
Black battery cable to positive and white to negative?
Picture would help.
http://photoposting.is-great.net/?i=1
Although replacing the entire power center seems extreme... may need some pictures there of the DC side.
675w Solar pictures back up
1977tgregg
Posted: 08/01/20 07:35pm Link  |  Quote  |  Print  |  Notify Moderator
This one is hooked up red to pos and black to negative. Traced positive wire (red) through the battery switch dack to the power center to positive on the board. Will post some pics tomorrow.
Wherever I happen to park
Posted: 08/02/20 05:40am Link  |  Quote  |  Print  |  Notify Moderator
OPTION one already discussed Backwards battery
Option 2 shorted battery or other short
Home is where I park it.
ndrorder
Southwest
Posted: 08/02/20 07:34am Link  |  Quote  |  Print  |  Notify Moderator
Has the trailer been connected to the tow vehicle when the fuses blew. Could the charge line polarity be reversed?
__________________________________________________
Cliff
2011 Four Winds Chateau 23U
dougrainer
Carrolton, Texas
Posted: 08/02/20 09:21am Link  |  Quote  |  Print  |  Notify Moderator
When a WFCO RP fuses BLOW, that means you had the DC power supply from the battery reversed. BUT, when that happens, you should be able to replace those 2 fuses and correct polarity and everything should be OK. BUT, If when you blew those fuses, and you then connected 120 to the WFCO, that would blow the capacitors on the Converter section and render it BAD. So, since you state you replaced the Power Center you should be good to go. UNLESS and the last part of your post is muddled, did you replace the Power Center BEFORE you verified Battery polarity was correct? You stated you did not troubleshoot correctly and missed a step. What was that missed diag and step? Doug
RJsfishin
Winston Or.
Posted: 08/02/20 09:53pm Link  |  Quote  |  Print  |  Notify Moderator
Why would you replace the power center. That just adds to the trouble shooting.
Rich
'01 31' Rexall Vision, Generac 5.5k, 1000 watt Honda, PD 9245 conv, 300 watts Solar, 150 watt inv, 2 Cos 6v batts, ammeters, led voltmeters all over the place, KD/sat, 2 Oly Cat heaters w/ ox, and towing a 2012 Liberty, Lowe bass boat, or a Kawi Mule.
