RV.Net Open Roads Forum: Tech Issues: 7.5 Onan Diesel Generator
 > 7.5 Onan Diesel Generator
2000 American Eagle
Utah
Posted: 08/01/20 09:25pm Link  |  Quote  |  Print  |  Notify Moderator
My Onan Generator is currently shutting down after running for a short time. I have had problems with this generator in our 2000 American Eagle since we purchased it in 2017. I had 210 hrs when we purchased it in 2017 and now 325 hrs. I had a very qualified technician check it out and replaced the control panel in 2017. I turn it on several times a year, load it up and it has been working most of the time. It seems to shut down when I need it. The code was 33 coolant high temp. I have changed thermostat, radiator cap, sensor, fuel filter, air filter. it is still shutting down with code 1 high temp. Any suggestions?
bobsallyh
Livingston, TX.
Posted: 08/02/20 10:42am Link  |  Quote  |  Print  |  Notify Moderator
2000 American Eagle, can't help with the diesel Onan, we have a gas POS. Onan's are like an old woman, lot's of TLC!
Flute Man
Payson, Arizona
Posted: 08/02/20 09:41pm Link  |  Quote  |  Print  |  Notify Moderator
How about the radiator or the fan? Does it overheat on no load?
Jerry Parr
05 Mandalay 40B
Cat C7 350
04 Honda CR-V
Ham Radio K7OU
Retired EE
Jrparr32@gmail.com
602-321-8141
Full-timer
Cloud Dancer
San Antonio and Livingston TX USA
Posted: 08/02/20 09:58pm Link  |  Quote  |  Print  |  Notify Moderator
It could very well be mineral deposits inside the cooling tubes of the radiator. That's what it was on mine (same model of generator on my 2003 Dutch Star). I removed the radiator and took it to a radiator shop for a complete cleaning procedure. The problem never came back.
Willie & Betty Sue
Miko & Sparky
2003 41 ft Dutch Star Diesel Pusher/Spartan
Floorplan 4010
Blazer toad & Ranger bassboat
hypoxia
Arizona
Posted: 08/03/20 05:01am Link  |  Quote  |  Print  |  Notify Moderator
Have you pulled the coolant fill hose with the radiator cap out and extended it above the top of the generator and topped off the coolant?
Jim
2007 Monaco Signature Noble III ISX 600HP
Shot-N-Az
Just South of DC
Posted: 08/03/20 06:42am Link  |  Quote  |  Print  |  Notify Moderator
https://www.youtube.com/watch?v=0LB5ZhvhXas&t=146s
