RV.Net Open Roads Forum: Class A Motorhomes: Carrier air v won’t start
 > Carrier air v won’t start
prento
england
Posted: 08/02/20 02:13am Link  |  Quote  |  Print  |  Notify Moderator
Hi all my carrier air v will now not start you press the remote it beeps twice but won’t turn on,I’ve reset the remote But still the same any ideas.
Wherever I happen to park
Posted: 08/02/20 05:50am Link  |  Quote  |  Print  |  Notify Moderator
Answered elsewhere but just recalled something.
The BEEP BEEP Means the remote is working but is it on A/C or some other mode like HEAT? (Forgot that in my other response)
It also means 12 volts is getting to the unit and the electronic part of the controls is working
now on the 120 volt side of life
On my rig I had that problem when nearly new (less than 5 months) found several screws loose in the breaker box.. NOTE UNPLUG BEFORE TIGHTENING one took over 3 turns A/C worked fine after that till they failed due to Bad Design.
Still work fine now that they have been upgradeed.
There are relays on the control board... IN my RV I have two OTHER control boards that have failed.. On one I've diagnosed relay failure (Will rebuild)
Plugs can unplug. wires get moused. For both Blower and Compressor motors to fail at the same time... Not likely
Home is where I park it.
rwess
Georgia
Posted: 08/02/20 06:48am Link  |  Quote  |  Print  |  Notify Moderator
The Carriers were very bad. I had 2 Carrier heat pumps on my 2011 Open Range. Supposedly, Open Range bought all remaining stock of Carrier RV A/C & heat pumps when Carrier got out of the RV business and Open Range was just starting. Constant problems all the time. Open Range apparently knew the Carrier's were bad and willingly replaced them before my 2 year warranty had expired. Needless to say I was shocked that they agreed to replace them so easily. The original Open Range company really stood by their products.
rwess
USN Ret.
2017 Open Range 216RBS
2010 Chevy 2500HD Z71 4x4 LT
schlep1967
Harrisburg, PA
Posted: 08/02/20 02:04pm Link  |  Quote  |  Print  |  Notify Moderator
I had the exact same thing this weekend. The 50 amp service only had power on one leg. According to the manual 2 beeps means a problem with the power.
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
dougrainer
Carrolton, Texas
Posted: 08/02/20 03:29pm Link  |  Quote  |  Print  |  Notify Moderator
Service Manual. Doug
Good Luck
https://www.gmcmi.com/wp-content/uploads/2015/08/Carrier-AirV-service-manual.pdf
Posted: 08/02/20 03:39pm Link  |  Quote  |  Print  |  Notify Moderator
Two beeps means two actions
BEEP I'm on
Beep Temp set
One beep when turning off (Since no need to set temp turning off)
Been operating one for 15 years +
There is a LED light on the control board above the filters but I do not know the blink code
Here we go.. Two resources for you
First find and observe that blinking or non blinking light
Service manual
If you can not see the LED. Odds are 120vac not delivered to Roof.
Note the Rooftop service manual says Green LED 5 Blinks no power.
But with carrier.. Well. I have not tested (will check sometime)
Horsedoc
Dixie --- N. Georgia
Posted: 08/02/20 04:31pm Link  |  Quote  |  Print  |  Notify Moderator
We had carrier on a previous coach. Try turning all the power off on the coach for about 10 minutes. Unplug the coach and turn the batteries off. Had a tech who wanted to charge me $100 to diagnose the problem, but would only be able to do the next morning. In fairness, he was going to have to drive from Rapid to Custer to check it. I called another shop and the guy there told me to do what I described. Worked like he said it would. Started right up when I re-connected.
Horsedoc
Posted: 08/02/20 04:33pm Link  |  Quote  |  Print  |  Notify Moderator
We had Carrier units on a previous coach. Try turning all the power off on the coach for about 10 minutes. Unplug the coach and turn the batteries off. Had a tech who wanted to charge me $100 to diagnose the problem, but would only be able to do the next morning. In fairness, he was going to have to drive from Rapid to Custer to check it. I called another shop and the guy there told me to do what I described. Worked like he said it would. Started right up when I re-connected.
prento
england
Posted: 08/03/20 01:04am Link  |  Quote  |  Print  |  Notify Moderator
There is a very small red flashing light in the unit that is flashing off and on (not in a code)
Posted: 08/03/20 04:48am Link  |  Quote  |  Print  |  Notify Moderator
I think flashing red is normal but not sure. I posted a link to the service manual do not recall seeing red mentioned.
