RV.Net Open Roads Forum: How to empty fresh water tank without pump?
 > How to empty fresh water tank without pump?
someuser001
seattle
Posted: 08/02/20 10:48am Link  |  Quote  |  Print  |  Notify Moderator
My water pump is not working and I need to get it replaced.
Is there a way to empty the full fresh water tank without the use of a water pump?
I have 2018 Forest River sunseeker
ken56
Tennessee
Posted: 08/02/20 10:51am Link  |  Quote  |  Print  |  Notify Moderator
There should be a low point valve under the trailer for the tank. Why do you need to empty the tank to replace the pump? Why do you think the pump is not working? Whats it doing?
near Jawbone Canyon, CA
Posted: 08/02/20 11:05am Link  |  Quote  |  Print  |  Notify Moderator
You should have used the low point drain a number of times before this incident. For instance to drain the fresh water system after sanitation.
wopachop
Who run bartertown
Posted: 08/02/20 11:08am Link  |  Quote  |  Print  |  Notify Moderator
Can you hear the pump turning on?
someuser001
seattle
The tank is completely full. So I want to avoid driving down the highway with a full tank. I guess it should be ok. But seeing if I can empty it before for better gas mileage
For the pump. It keeps running. But no water comes out the tap. Any ideas how to debug? I was going to take it to a shop
This not a trailer but a class c. Where would I find this valve. I have looked below but cannot find it. Any ideas what it might look like?
someuser001
seattle
Posted: 08/02/20 11:09am Link  |  Quote  |  Print  |  Notify Moderator
The pump turns on and runs. But no water comes out
IAMICHABOD
Sunny So Cal 90713
Posted: 08/02/20 11:25am Link  |  Quote  |  Print  |  Notify Moderator
If you can find your water tank it may have a drain on one side of it like this,
Turn the valve so lines up with the pipe and it will drain under the RV.
Or if you can follow the line to the water pump sometime there is a valve there that you open and it lets the water out under the RV.
Former El Monte RV Rental
Buying A Rental Class C
Chevrolet Based Class C
KD4UPL
Swoope, VA
Posted: 08/02/20 11:33am Link  |  Quote  |  Print  |  Notify Moderator
Every RV I've ever owned had a drain underneath somewhere to drain the fresh water tank. You'll just have to look around for yours or check the manual.
Emptying the tank won't help your fuel mileage one bit. Fuel mileage in an RV is a lot more about aerodynamics than weight. Even if it were about weight you're talking about what 2% of the total weight?
The pump mechanism likely just needs a new valve. They can be rebuilt without removing the motor and all.
If it were mine, and I couldn't find the drain valve, I'd just pinch the pipe between the tank and the pump with vice grips while I was rebuilding the pump.
Bumpyroad
Virginia
Posted: 08/02/20 11:37am Link  |  Quote  |  Print  |  Notify Moderator
did a valve somehow get switched so it is trying to pull water in from a remote fill rather than the tank? there has gotta be a drain however.
bumpy
pianotuna
Regina, SK, Canada
Posted: 08/02/20 11:40am Link  |  Quote  |  Print  |  Notify Moderator
let's assume a 40 us gallon tank. About 300 lbs of water
The weight (measured) of my RV is 13750 lbs. But let's round that down to 13000 lbs.
300/13000 = 2.3%
I think you may be hard pressed to measure the difference in mileage.
Regards, Don
