RV.Net Open Roads Forum: Fifth-Wheels: Worn inside Tires
 > Worn inside Tires
lenr
Indianapolis, IN
Posted: 08/03/20 06:45pm Link  |  Quote  |  Print  |  Notify Moderator
Our fifth wheel came with 5100 lb axles--loaded with our normal personal possessions and fresh water, the two axles weigh 10,220 lbs. So, they were loaded right up to the limit and probably ready to bend at the slightest abuse. We upgraded to 6,000 lb axles and disc brakes. OP might want to consider upgrading to a heavier wall tube. Dexter makes 3 wall thicknesses of 3" axle tubes ranging from 5100 to 7000 lb axles. RV manufacturers are going to use the cheapest, thinnest, axle tubes rated for what they're building.
* This post was edited 08/04/20 07:52am by lenr *
Edd505
Elephant Butte, NM
Posted: 08/03/20 08:25pm Link  |  Quote  |  Print  |  Notify Moderator
Might check wheel bearing and see if they are loose.
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
Njmurvin
Simi Valley
Posted: 08/10/20 05:05pm Link  |  Quote  |  Print  |  Notify Moderator
I had mine aligned after uneven wear following a long trip over I5 from Oregon to L.A. I took it to an axle specialist. Total bill was $325 for both axles. No problem since.
2020 Chevy Silverado 3500HD Duramax 4x4 Crew Cab Standard box
2011 Arctic Fox 27.5L
allen8106
Burrton. KS
Posted: 08/12/20 12:39pm Link  |  Quote  |  Print  |  Notify Moderator
JKwock wrote:
Verify my suspicions. I have worn tires on the rear axle tires on the inside. Very worn to a point I saw steel showing. The other tires are fine. Im guessing I don't have enough camber on the rear axle? What do you guys think?
Jason
You need an alignment.
I get mine aligned every two years as part of my regular maintenance.
2010 Eagle Super Lite 315RLDS
2018 GMC Sierra 3500HD 6.6L Duramax
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 76
2020 Nights 68
 > Worn inside Tires
