RV.Net Open Roads Forum: Tech Issues: Setting up my solar system
 > Setting up my solar system
Page of 8
GravelRider
Pennsylvania
Posted: 08/12/20 12:45pm Link  |  Quote  |  Print  |  Notify Moderator
CA Traveler wrote:
That's a good price. I paid $200 for 250W a few years ago and todays prices are half.
That's good to hear. That was better than anything I could find, after figuring in shipping especially, other than some used poly panels on Craigslist. They were selling for $105 OBO per 265 watt panel, and he had about 40 of them available. I was seriously considering that, but the dimensions didn't work for my RV roof. These 400 W panels are perfect.
bpounds
Sophmore Brain...
Posted: 08/12/20 01:23pm Link  |  Quote  |  Print  |  Notify Moderator
I had mixed results using a stud finder, but a neodymium magnet found them easily and reliably. This was a trussed roof with rubber overlayment.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
bpounds
Sophmore Brain...
Posted: 08/12/20 01:28pm Link  |  Quote  |  Print  |  Notify Moderator
GravelRider wrote:
I've got a 96" x 115" area forward of the air conditioner...
Wow, I never would have guessed that. Never seen that much non-penetrated space. Two of those panels will be sweet.
CA Traveler
The Western States
Posted: 08/12/20 01:52pm Link  |  Quote  |  Print  |  Notify Moderator
Panel size didn't line up with the beams and I didn't use the 4' beams initially.
The roof is peaked and the beams are flat on 4' centers. Removing some ceiling items like lights determined one location. I drilled a small hole next to one from inside to determine it's exact center location from the roof. From the roof for other beams I drilled a small hole and used a small wire to confirm. I used 3" screws to secure the al angle.
2014 Grand Cherokee Overland
Bob
GravelRider
Pennsylvania
Posted: 08/12/20 02:32pm Link  |  Quote  |  Print  |  Notify Moderator
Unfortunately mine is stick framed. As far as I know there are no metal roof beams that I'm aware of. Grey Wolf 22MKSE
GravelRider
Pennsylvania
Posted: 08/12/20 02:35pm Link  |  Quote  |  Print  |  Notify Moderator
I was actually surprised too when I went up to measure, as it's not a large trailer. Though it's also pretty basic, so not too much stuff up there to take up space. However, in that 96x115" space, there is the stock 50 watt solar panel that I will have to remove. I'm planning to just remove the panel from the mounts and leave the mounts in place. Or maybe it would be better to remove them as well and use generous amounts of lap sealant and/or eternabond tape?
bpounds
Sophmore Brain...
Posted: 08/12/20 03:04pm Link  |  Quote  |  Print  |  Notify Moderator
Mine is wood frame roof too. Truss refers to wood construction. The magnet finds the staples or screws that secure the sheathing to the trusses (rafters if you prefer).
GravelRider
Pennsylvania
Posted: 08/12/20 03:18pm Link  |  Quote  |  Print  |  Notify Moderator
Ah, I see. Good idea on the magnets. I'll definitely use that if my stud finder isn't much help.
GravelRider
Pennsylvania
Posted: 08/12/20 03:19pm Link  |  Quote  |  Print  |  Notify Moderator
Good to know. I'm hoping my install goes a bit easier. This is making me consider those glue-down no-drill mounts... But I don't know that I'd ever be comfortable driving down the road with glue-on mounts...
CA Traveler
The Western States
Posted: 08/12/20 05:27pm Link  |  Quote  |  Print  |  Notify Moderator
If those mounts are Z mounts pitch them. Instead use 2x al angle connected with a bolt like a Z and the panels are much easier to remove when needed.
A number of posters have used only 3M VHB tape to secure panels. I used VHB tape, screws and sealed with Dicor.
* This post was edited 08/12/20 05:33pm by CA Traveler *
Page of 8
