Timeking
Florida USA
As everyone knows, if you put a dark object and a white object out in the burning hot Florida sun, the dark object will be MUCH hotter than the white object. At some point in the genius of things, Carefree and other manufacturers' awnings are installed 'dark side up, white side down'. Sorry, but this seems dumb for 3 solid reasons:
1) dark side up means the bottom of the awning becomes an infrared radiator, so you swelter in the shade. Dumb.
2) white side down only means that it gets stained, and many stains never can be removed, so you're sitting under something ugly. And hot.
3) Once rolled out, the "decorative" side is only visible from an airplane, and when rolled up mostly invisible.
So ... is it possible to take the awning off, and install upside down? White side up to reflect the heat and get all ugly where you can't see it? And decorative side down giving you a sense of an attractive environment?
Bishop area, California
“Once rolled out, the "decorative" side is only visible from an airplane, and when rolled up mostly invisible.” I disagree. Most are visible unrolled. Five years on current awning...no stains, no super precautions.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-parallel & MPPT, Trojan T-125s. TALL flag pole. Prefer USFS, COE, BLM, NPS, TVA, state & county camps. Bicyclist! 14 year Army vet-11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
camperdave
northern, California
I don't know about all awnings, but it wouldn't work on mine due to the way the holder rod (for lack of a better term) is sewn in on the roller side of the awning.
2004 Fleetwood Tioga 29v
Roger10378
Goodrich, MI.
X2
2005 Cardinal 30TS
2007 Chevy 2500HD D/A
Edd505
Elephant Butte, NM
Order white on white, when it's dirty flip it over.
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
valhalla360
No paticular place.
Replaced a slide out cover a few years back and it didn't matter which side was up. Of course, both sides were white.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
trailrider
Idaho Is Full! Don't Move Here!!!
Yes, you can install it upside down.
2020 Chevrolet Silverado 3500HD GAS!!!
1978 Chevrolet Silverado K20 4x4
2007 Komfort 277TS
2020 Sherco 300 SEF Factory
2018 Honda Rancher TRX420FA6
2017 Montesa 4RT260
2021 Honda CRF450X
John Wayne
Long Beach, Ca
don't think you can do it if you have the metal cover type. If not the little flappy thing that blows in the wind on the outside of the unrolled awning will be on the inside rolled between the awning and roller but it should work inside out.
John & Carol Life members
01 31'Sea View single slide, F53 V-10 with 134,000 miles and counting.
2012 Jeep Liberty Smi brake system
Security by Bentley
God Bless
KF6HCH
bucky
Raleigh metro
Cut that little flappy thing off if needed .
2005 Cummins 3500 2WD LB quad cab dually pulling a 2014 Blue Ridge 3025RL
ksg5000
Oregon
Awnings aren't that expensive unless your having them installed - if it were me I would just buy a white awning.
Kevin
