RV.Net Open Roads Forum: Tech Issues: awning fabric - install upside down possible?
 > awning fabric - install upside down possible?
Timeking
Florida USA
Posted: 08/07/20 11:10am Link  |  Quote  |  Print  |  Notify Moderator
As everyone knows, if you put a dark object and a white object out in the burning hot Florida sun, the dark object will be MUCH hotter than the white object. At some point in the genius of things, Carefree and other manufacturers' awnings are installed 'dark side up, white side down'. Sorry, but this seems dumb for 3 solid reasons:
1) dark side up means the bottom of the awning becomes an infrared radiator, so you swelter in the shade. Dumb.
2) white side down only means that it gets stained, and many stains never can be removed, so you're sitting under something ugly. And hot.
3) Once rolled out, the "decorative" side is only visible from an airplane, and when rolled up mostly invisible.
So ... is it possible to take the awning off, and install upside down? White side up to reflect the heat and get all ugly where you can't see it? And decorative side down giving you a sense of an attractive environment?
Camping near Pearsonville, CA
Posted: 08/07/20 11:49am Link  |  Quote  |  Print  |  Notify Moderator
“Once rolled out, the "decorative" side is only visible from an airplane, and when rolled up mostly invisible.” I disagree. Most are visible unrolled. Five years on current awning...no stains, no super precautions.
camperdave
northern, California
Posted: 08/07/20 11:59am Link  |  Quote  |  Print  |  Notify Moderator
I don't know about all awnings, but it wouldn't work on mine due to the way the holder rod (for lack of a better term) is sewn in on the roller side of the awning.
2004 Fleetwood Tioga 29v
Roger10378
Goodrich, MI.
Posted: 08/07/20 12:11pm Link  |  Quote  |  Print  |  Notify Moderator
X2
2005 Cardinal 30TS
2007 Chevy 2500HD D/A
Edd505
Elephant Butte, NM
Posted: 08/07/20 12:16pm Link  |  Quote  |  Print  |  Notify Moderator
Order white on white, when it's dirty flip it over.
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
valhalla360
No paticular place.
Posted: 08/07/20 12:38pm Link  |  Quote  |  Print  |  Notify Moderator
Replaced a slide out cover a few years back and it didn't matter which side was up. Of course, both sides were white.
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
trailrider
new plymouth, idaho
Posted: 08/07/20 01:37pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, you can install it upside down. [emoticon]
2020 Chevrolet 3500HD GAS!!!
1978 Chevrolet K20 4x4
2007 Komfort 277TS
2020 Sherco 300 SEF Factory
2018 Honda Rancher TRX420FA6
2017 Montesa 4RT260
John Wayne
Long Beach, Ca
Posted: 08/07/20 03:17pm Link  |  Quote  |  Print  |  Notify Moderator
don't think you can do it if you have the metal cover type. If not the little flappy thing that blows in the wind on the outside of the unrolled awning will be on the inside rolled between the awning and roller but it should work inside out.
John & Carol Life members
01 31'Sea View single slide, F53 V-10 with 134,000 miles and counting.
2012 Jeep Liberty Smi brake system
Security by Bentley
God Bless
KF6HCH
bucky
Raleigh metro
Posted: 08/08/20 04:17am Link  |  Quote  |  Print  |  Notify Moderator
Cut that little flappy thing off if needed [emoticon].
2005 Cummins 3500 2WD LB quad cab dually pulling a 2014 Blue Ridge 3025RL
ksg5000
Oregon
Posted: 08/08/20 08:41am Link  |  Quote  |  Print  |  Notify Moderator
Awnings aren't that expensive unless your having them installed - if it were me I would just buy a white awning.
Kevin
