RV.Net Open Roads Forum: Fifth-Wheels: 5th Wheel with no dually truck
 > 5th Wheel with no dually truck
Pipeman
Windsor, Ontario,
Posted: 08/08/20 04:58am Link  |  Quote  |  Print  |  Notify Moderator
I have a dually and it is my daily driver. I don't have a problem with it at all. It is 9 years old and a diesel, long box, 4 door and seats 5 people.I haul a 35 ft 5er with it. In my opinion there isn't any reason to be leery about using a dually as a daily driver. My 3 cents
Pipeman
Ontario, Canada
35 year Fire Fighter(retired)
VE3PJF
4x4ord
Alberta
Posted: 08/08/20 02:20pm Link  |  Quote  |  Print  |  Notify Moderator
The more weight I get on the pin of my fifth wheel hitch in the bed of my truck the nicer the truck pulls. I would much rather pull a 14000 lb 5ver having a 3000 lb pin with my SRW than a tag trailer of any weight.
2017 F350 SRW Platinum short box 4x4.
B&W Companion
Allworth
Orlando, FL
Posted: 08/08/20 04:19pm Link  |  Quote  |  Print  |  Notify Moderator
I pull 13,500# with my 3500 SRW long bed diesel and have never felt that I needed more truck.
Florida, New England, Nova Scotia, Yellowstone, Alaska, Yosemite, Monarch Pass, and everywhere in between.
A
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
2008 Titanium 30E35SA; EZ-Lube axles; wet bolts; spring hanger gussetts; BFG Commercial TAs
"Real Jeeps have round headlights"
StirCrazy
Kamloops, BC, Canada
Posted: 08/08/20 06:19pm Link  |  Quote  |  Print  |  Notify Moderator
I tow a 40' 5th with a 2800 lb pin weight and I still have 1000 lbs left over in my 2014 F350 crew cab long box. I do have the 11500 lb GVW option though. thats one thing to look at for the truck, you can get higher payload and GVW packages depending on options.
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
mtofell1
Oregon
Posted: 08/08/20 07:52pm Link  |  Quote  |  Print  |  Notify Moderator
15K loaded 5th wheel is well within all numbers for any of the new SRW 350/3500s. I probably wouldn't go too far above that without going up to a DRW.
ACZL
UPstate,NY
Posted: 08/09/20 08:34am Link  |  Quote  |  Print  |  Notify Moderator
1 ton SRW will handle anything w/ ease under 15k. No need for DRW in the senerio you spoke of.
2017 F350 DRW XLT, CC, 4x4, 6.7
2018 Big Country 3560 SS
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
TXiceman
Full Time RVer
Posted: 08/09/20 09:34am Link  |  Quote  |  Print  |  Notify Moderator
Yes, but it must be a properly equipped SRW, Go back a few years and they will not have enough payload capacity.
On the newer truck, look for the yellow sticker on the drivers door jamb. It will provide the payload capacity of that particular truck. With the paylaod capacity, you can add the trailer loaded pin weight plus the hitch, plus passengers, plus any cargo to get your total payload. This total must be lower than the payload on the sticker.
You can use this method or weigh the truck and get the base line numbers.
Ken
Amateur Radio Operator.
4x4ord
Alberta
Posted: 08/10/20 09:34am Link  |  Quote  |  Print  |  Notify Moderator
^^^^ or many of us ignore the payload number and detetmine the maximum pin weight by subtracting the truck's approximate rear axle weight beore hooking up the trailer from the rear axle weight rating.
cummins2014
Utah
Posted: 08/10/20 09:48am Link  |  Quote  |  Print  |  Notify Moderator
The determining factor for me would be the tire ratings . No idea what the newer 1 ton SRW trucks come with these days ,but mine came with tires rated for 3640 Lbs. in 2014
klr650goldwing
minnesota
Posted: 08/21/20 06:42pm Link  |  Quote  |  Print  |  Notify Moderator
We started RVing with a 10,000 pound 5er and a SRW f350 V10 truck. All was well. Then we bought a 12,700 pound 5er and the same truck wasn't as much fun. It lacked adequate power on the steeper grades and the trailer seemed to push the truck around some. So we bought a F350 DRW 6.7 and the difference is miraculous. This truck makes towing a breeze. By the way, the new trailer is a Grand Design. We absolutely love it.
2014 Grand Design Solitude 369RL
2017 F350 6.7 DRW CC LB 4X4
2012 Mercedes E550
2010 Honda Civic
2009 Saab 93 Aero Convertible
2004 Honda Goldwing GL1800
2004 Kawasaki KLR650
1966 Honda 305 Dream
