RV.Net Open Roads Forum: Travel Trailers: ACME nut destroyed
 > ACME nut destroyed
jerem0621
Tennessee
Posted: 08/09/20 01:05am Link  |  Quote  |  Print  |  Notify Moderator
Set up the Camper at the local campground and was checking the propane and look what I found.
Camper is less than 3 months old.
Guess I’ll be adding a new pigtail as the gas to pull the trailer to the dealer is more than the pigtail.
Anyone ever experienced this?
Thanks!
Jeremiah
TV- 2011 Chevy Tahoe, 2WD, Hayden transmission cooler
TT - Zinger 270BH
WD Hitch- HaulMaster 1,000 lb Round Bar
Dual Friction bar sway control
Tekonsha Voyager brake controller (Great Brake Controller)
It’s Kind of Fun to do the Impossible
~Walt Disney~
MFL
Midwest
Posted: 08/09/20 04:40am Link  |  Quote  |  Print  |  Notify Moderator
Not me...I stop at tight is good, not tighter is better! [emoticon]
Jerry
midnightsadie
ohio
Posted: 08/09/20 05:50am Link  |  Quote  |  Print  |  Notify Moderator
easy fix. never seen that before .
Bumpyroad
Virginia
Posted: 08/09/20 05:56am Link  |  Quote  |  Print  |  Notify Moderator
tried lefty loosey, righty tighty?
bumpy
Tvov
CT
Posted: 08/09/20 05:58am Link  |  Quote  |  Print  |  Notify Moderator
I'm not really surprised... I've always thought that the gas lines to the tanks are very stiff. Seems like a lot of sideways pressure when I screw those connectors on. Add in lowest bidder to make the part, and that's what you get.
2008 F-250 CrewCab 5.4L,
noteven
Turtle Island
Posted: 08/09/20 06:04am Link  |  Quote  |  Print  |  Notify Moderator
There is something about the coeficient of the radial expansion along the longitudinal axis of these connectors on my truck camper - I install them nicely hand tight on the cylinders. One of them sometimes needs a water pump plier and a rag to move it to disconnect. The other is removeable by hand...
Lynnmor
Red Lion
Posted: 08/09/20 06:05am Link  |  Quote  |  Print  |  Notify Moderator
I've read about those cheap Chinese junk pigtails.
Old-Biscuit
Verde Valley
Posted: 08/09/20 07:30am Link  |  Quote  |  Print  |  Notify Moderator
LP ACME Nuts should be installed hand tight....and seal,
Should NOT need any wrenches/pliers etc to tighten
IF having to use tools..then pigtails are too short and binding...as evicenced by the tight loop/90* your pigtail is having to make from reg to Cylinder OPD
US NAVY------USS Decatur DDG31
BB_TX
McKinney, Texas
Posted: 08/09/20 09:20am Link  |  Quote  |  Print  |  Notify Moderator
Agree on tightness. Hand tight, and that doesn't mean turn as hard as you can, and then turn a little more. The old thought of tight is good and tighter is better is not a good rule of thumb.
Thermoguy
Graham, WA
Posted: 08/09/20 09:38am Link  |  Quote  |  Print  |  Notify Moderator
It looks to me like those plastic fittings are exposed to sun and air all the time. It is plausible that they get brittle with age and just broke. Would probably benefit from a cover to keep from drying out.
