RV.Net Open Roads Forum: Travel Trailers: ACME nut destroyed
 > ACME nut destroyed
Admin
Channel Islands Harbor, Ca.
Administrator
Posted: 08/09/20 10:51am Link  |  Quote  |  Print  |  Notify Moderator
Keep out of sun, wrap with tape or aluminum foil.
Remove stress on hose from sharp bend if possible.
If you can't bend the hose to put it on the tank easily, it's too sharp a bend.
Admin
jerem0621
Tennessee
Posted: 08/09/20 05:59pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks everyone, these are BRAND NEW. It’s a 2020 and always under a cover. As a matter of fact, this was fine two weeks ago when we last camped. Just funny.
TV- 2011 Chevy Tahoe, 2WD, Hayden transmission cooler
TT - Zinger 270BH
WD Hitch- HaulMaster 1,000 lb Round Bar
Dual Friction bar sway control
Tekonsha Voyager brake controller (Great Brake Controller)
It’s Kind of Fun to do the Impossible
~Walt Disney~
CharlesinGA
South of Atlanta, Georgia
Posted: 08/09/20 09:10pm Link  |  Quote  |  Print  |  Notify Moderator
Buy pigtails made by Marshall Excelsior. They will be USA made, including the hose. I buy the steel braided version. You probably have the hose with the reverse flare on the regulator end, and probably 15 inch.
15 inch, green nut, steel braid LP tank pigtail
Charles
rhagfo
Portland, OR
Posted: 08/10/20 12:04am Link  |  Quote  |  Print  |  Notify Moderator
Better have them made by local propane distributor, they will use better hose.
jerem0621
Tennessee
Posted: 08/10/20 12:27pm Link  |  Quote  |  Print  |  Notify Moderator
Charles
Thank you! I will order one.
Jeremiah
jerem0621
Tennessee
Posted: 08/10/20 12:30pm Link  |  Quote  |  Print  |  Notify Moderator
I didn't know you can have these made locally. I'll check into it.
Thanks!
Jeremiah
Turtle n Peeps
California
Posted: 08/10/20 06:51pm Link  |  Quote  |  Print  |  Notify Moderator
Looks like something hit this to me? With plastic still on the tank something fell on it or hit it?
outside the fire"
"The best way to get a bad law repealed is to enforce it strictly."- Abraham Lincoln
CavemanCharlie
Storden,MN
Posted: 08/11/20 08:21pm Link  |  Quote  |  Print  |  Notify Moderator
I was thinking the same thing
BarabooBob
Baraboo, WI
Posted: 08/12/20 07:51pm Link  |  Quote  |  Print  |  Notify Moderator
X3 on the something was dropped on the connection.
Bob & Dawn Married 32 years
2017 Viking 17RD
2011 Ford F150 3.5L Ecoboost 420 lb/ft
Retired
lane hog
Tucson, AZ & NW Chicago Burbs, IL
Posted: 08/12/20 09:56pm Link  |  Quote  |  Print  |  Notify Moderator
That's damaged, not a failure.
No need to rush out to replace it - the pigtail from the other tank should reach if you run that tank empty.
  • 2019 Grand Design 29TBS (had a Winnebago and 3x Jayco owner)
  • 2016 F-150 3.5L MaxTow (had Ram 2500 CTD, Dodge Durango)
  • 130W solar and 2005 Honda EU2000i twins that just won't quit
