RV.Net Open Roads Forum: Travel Trailers: airtabs
Lynnmor
Red Lion
Posted: 08/10/20 06:41am Link  |  Quote  |  Print  |  Notify Moderator
bucky wrote:
Also yes. What do you think those giant vertical and horizontal flaps at the loading doors are on semi trailers for?
You can always tell an owner operator, they will have them deployed. A company driver will not take the time as it's not his dime.
They are not the Airtabs, they are something that actually works.
TravelinDog
Nevada
Posted: 08/10/20 03:47pm Link  |  Quote  |  Print  |  Notify Moderator
Airtabs are nothing more than snake-oil designed to lighten your wallet.
StirCrazy
Kamloops, BC, Canada
Posted: 08/10/20 05:19pm Link  |  Quote  |  Print  |  Notify Moderator
air tabs work, but dont expect a mirical. my buddy ut them on his 5th wheel and picked up 1 mpg, but noted the biggest improvment was in the handling when passing a rif or in high winds. they basicly work like vortex generators on a planes wing tips, this disrupts the airflow and reduces the low pressure drag area behind the trailer which reduces the drag. depending on what your towing they can make a big difference or a little difference. I would suspect the lowest fule milage in crease would be on a conventional trailer and the best on a truck camper. the trailer has two large drag zones, one behind the truck and another behind the trailer so you would have to fix both to get a biger increase. the camper only has one. a fith is inbetween as the nose of the trailer is closer to the truck reducing the size of that drag area.
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
pianotuna
Regina, SK, Canada
Posted: 08/10/20 05:32pm Link  |  Quote  |  Print  |  Notify Moderator
That is not my experience with them. I would buy them again--unless I could find something better.
Regards, Don
profdant139
Posted: 08/10/20 05:54pm Link  |  Quote  |  Print  |  Notify Moderator
Here's a link to a NASA study of Airtabs:
NASA
The real issue is cost vs benefit. For long-haul truckers, even a fractional increase in mpg justifies the expense. (And yes, we often see trucks with Airtabs.) For recreational RVers, it is a closer call -- how many miles would you have to drive in order to break even?
However, if the Airtabs not only increase mpg but also improve handling, then the cost may well be justified. That is a matter of personal preference.
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
bnardini
Kingman, AZ
Posted: 08/13/20 09:57am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the input everybody. Got nothing better to do this winter. Might install some and see what happens. The NASA article was very interesting.
* This post was edited 08/13/20 10:05am by bnardini *
Bill & Lori Nardini finally on the road!
2008 Tundra SR5 doublecab
2009 Jayco 31 RKS G2
Gjac
Milford, CT
Posted: 08/13/20 10:50am Link  |  Quote  |  Print  |  Notify Moderator
To me they look like Naca Scoops used on aircraft, we used them on helicopters. I'm not an Areo guy but I think a Gurney flap on the trailing edge of an air foil on top of the rear cap might have a greater effect. We used this on the Horizontal stabilizer of the S-76 model. It is hard to compare the higher speeds of an aircraft to an RV traveling at 60 mph but I'm sure it would at least keep the rear window clean. Kind of like ram air/CAI on a MH it adds more HP mostly from cooler air very little from the ram effect unless you go 100 mpg plus but still worth doing.
mobeewan
Hampton, Va
Posted: 08/13/20 09:54pm Link  |  Quote  |  Print  |  Notify Moderator
Maybe Airtabs with nitrogen in the tires and dryer sheets you could get say maybe 50 mpg improvement.
pianotuna
Regina, SK, Canada
Posted: 08/13/20 10:29pm Link  |  Quote  |  Print  |  Notify Moderator
Only if you light the dryer sheets on fire and then drop them down your pants.
Turtle n Peeps
California
Posted: 08/14/20 09:10am Link  |  Quote  |  Print  |  Notify Moderator
The problem with any of this stuff is payback.
If you are putting aero gadgets on your trailer is like putting lipstick on a pig.
A trailer is super dirty aero wise. If you fix one thing there are 50 more things you can't fix. The wings we saw in the 70's were a prime example. How many wings do you see anymore? There is a reason.
This Caterpillar study show what is big in fuel savings As you can see, the way you drive your rid has the biggest fuel savings. Up to 20%. That's a very large savings. Route can be up to a 20% savings too. Between route and how you drive you can save a lot of fuel.
If you want to save fuel the best way is to slow down and drive sensible and pick the best route.
outside the fire"
"The best way to get a bad law repealed is to enforce it strictly."- Abraham Lincoln
