RV.Net Open Roads Forum: Travel Trailers: Which sewer hose?
 > Which sewer hose?
afidel
Cleveland
Posted: 08/09/20 08:04pm Link  |  Quote  |  Print  |  Notify Moderator
Had a Rhino for nearly 4 years, it just gave up, luckily while setting up! I ended up buying what they had at the campground as we were nearly an hour down the mountain to the nearest Walmart. Luckily it was a Camco Revolution kit which seems to have good reviews so I should be good for a few more years =)
2019 Dutchman Kodiak 293RLSL
2015 GMC 1500 Sierra 4x4 5.3 3.42 long bed
Equalizer 10k WDH
the e-man
Virginia
Posted: 08/10/20 06:44am Link  |  Quote  |  Print  |  Notify Moderator
Ruyack wrote:
Hello,
I am new to the world of travel trailers (and this forum)!
I purchased a 2019 Salem 26 dble. How do I know what kind of sewer hose I need?
I Googled it and all these sewer hoses popped up, but none of the ads mention my specific camper.
Thanks for your help! I'm looking forward to being part of this community!
Hi Ruyak,
Great question on the sewer hose. You are in the right place to learn.
There are several brands that make good sewer hoses. Rhinoflex is a good choice. So is Thetford Titan. Since every campsite is different, I find it is helpful to have options. I currently have a Thetford Titan 20 foot kit. It has two 10 foot hoses that connect together. I also kept my older Rhinoflex 15 foot hose as a spare.
Many recommend having a clear or semi-clear elbow so you can better see the flow.
Most people store their hose in their bumper. However, one thing I've found is that some of the better hoses have bigger connectors which means they may not fit in the bumper. Test your hose to ensure it fits before using it. If you really like a hose but find it doesn't fit in the bumper, you can install a sewer hose storage tube under the camper. Valterra makes a good one.
For a hose to work well, it needs to angle down from the camper to the sewer connection. Many people find having a support, like the Camco sidewinder, to be helpful.
For pictures and a description of our setup, check out Sewer Hose Setup.
2018 Grand Design Transcend 28MKS
2010 Ram 2500
Travel Trail Sail - Info on Travel Planning, RV Camping, Outdoor Living
Yosemite Sam1
Under the pines.
Posted: 08/10/20 10:46am Link  |  Quote  |  Print  |  Notify Moderator
Yes, as. stated above, sewer hoses are universal.
Added suggestion, get a transparent hose fittings. You don't want to have an accident removing the hose prematurely while those nasty fluid is still going down. Have fun. too pointing and teasing the wifey that that solid thingy going down. is hers.
camperdave
northern, California
Posted: 08/10/20 11:09am Link  |  Quote  |  Print  |  Notify Moderator
I don't like the clear elbows. I've dumped enough to know when it's done, I don't need to see it happening lol.
I have an el-cheapo hose for dump stations, and a Rhino Flex (2, actually) for hook up sites. I don't really care for the rhino for quick dumps, it's a little harder to handle.
I have connectors on both ends of all hoses so I can connect them all together if needed into one long hose. It also means I can connect them to themselves after use to eliminate any smell (I store them in a large plastic tub in a storage compartment, connecting them to themselves keeps everything clean in there). Once back home, I can do a good rinse and cleaning if needed.
2004 Fleetwood Tioga 29v
mockturtle
AZ
Posted: 08/10/20 01:44pm Link  |  Quote  |  Print  |  Notify Moderator
My Rhino is great but not without a learning experience. Since the parts all screw together in a different direction at the point of application, they can accidentally come loose and spill contents onto your shoes and elsewhere. Please don't ask. [emoticon]
2015 Tiger Bengal TX 4X4
Chevy 3500HD, 6L V8
 > Which sewer hose?
