RV.Net Open Roads Forum: Fifth-Wheels: Tires
 > Tires
Page of 7
Cummins12V98
on the road
Posted: 08/11/20 09:42am Link  |  Print  |  Notify Moderator
Campinfan wrote:
GY told me they don't make a tire that will work. They could not say why their inflation chart shows 95 and 110lbs of air pressure. I believe my trailer has a GVWR of 15K with over 2500 lbs of that being cargo capacity. I am going to order the Sailuns an have them mounted by Discount Tire. I will have to install them because there is no way I can maneuver my rig thru their parking lot. I think I will do 2 at a time and actually only have one tire jacked up at a time. I will use the spare to keep 3 wheels on the ground at a time....not sure if I NEED to do that but I feel more comfortable having only one at a time jacked up.
15k with 20% pin removed leaves 3k per tire. Either of the GY tires I mentioned will be just fine and you won't have to support Communist China.
GY told you that because your RV came with "F" tires.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Campinfan
Washtenaw County, Michigan
Posted: 08/11/20 07:41pm Link  |  Print  |  Notify Moderator
Thank you all for the advice. Maybe I will take all 4 at once, what ever tire I get. Maybe I will go weigh my trailer again and see the axle weights since it is loaded as if we were hitting the road...minus some food. You have all given me lots to think about.
______________________
2016 F 350 FX4 4WD,Lariat, 6.7 Diesel
41' 2018 Sandpiper 369 SAQB
Lovely wife and three children
Cummins12V98
on the road
Posted: 08/11/20 08:46pm Link  |  Print  |  Notify Moderator
Know your weights then decide.
cummins2014
Utah
Posted: 08/11/20 09:11pm Link  |  Print  |  Notify Moderator
It’s good to know your weight , but no way in the world would I run a Goodyear E or G rated tire on a 41’ fifth wheel @ 15,000 GVWR even if it is only 3000 per tire . I’d want my tires G rated and at least 4080 on weight rating . Those Goodyear’s just don’t get it done on weight ratings . There is no question on the Sailun S637’s in either the 235/80/16 or 235/85/16 . I run the 235/85/16 on my 15500 GVWR fifth wheel.
cummins2014
Utah
Posted: 08/12/20 10:06am Link  |  Print  |  Notify Moderator
Quality US made Goodyear G614's the issues just keep on coming, as well as the Endurance , blowouts ,plus wear issues . Great tire for the weekend warrior or light trailers ,not a good application for the heavier fifth wheels, just don't meet the weight ratings nor do they last.
How much more simple can we say it, the Goodyear tires do not have a capable rating for the bigger fifth wheels, Big reason you are seeing Westlakes , Sailuns etc. on bigger fifth wheels, that's a fact.
Montana used to offer the G614's , no longer.
allen8106
Burrton. KS
Posted: 08/12/20 12:37pm Link  |  Print  |  Notify Moderator
I installed Endurance on my 5th wheel back in early January and immediately took a 2500 mile round trip to Arizona and back traveling at 70-75 mph with no issues.
2010 Eagle Super Lite 315RLDS
2018 GMC Sierra 3500HD 6.6L Duramax
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 76
2020 Nights 68
cummins2014
Utah
Posted: 08/12/20 01:20pm Link  |  Print  |  Notify Moderator
Whole different ball game , then applying the Endurance 16" E rated tires to a heavy 41' fifth wheel. Comparing apples ,and oranges here.
Splashers3
Oakville, MD
Posted: 08/12/20 06:26pm Link  |  Print  |  Notify Moderator
I totally agree with Cummins2014.....how heavy your trailer weighs makes all the difference in tire choice.
I love my Westlake G rated tires....when time to replace it will either be them again, or Sailun 637s.
2017 GMC 3500 Sierra Denali, C/C, D/A, DRW, w/40gal Aux tank, 18K B&W Patriot.
2019 Cedar Creek Hathaway, 34RL2 - w/Bells & Whistles and disc brakes
Traded 2009 Cedar Creek Silverback, GII, 32 WRL
cummins2014
Utah
Posted: 08/12/20 06:54pm Link  |  Print  |  Notify Moderator
I had new Westlakes on the new to us fifth wheel we bought a few months ago , was skeptical about them not hearing much about them . I decided to sell them and get the Sailuns . They were identical to the Sailuns , couldn’t tell them apart other then the name on them . They too were an All Steel radial .
There is several of these All Steel radials showing up from overseas, I have the feeling they are going to prove out being the same quality as the Sailuns. Westllake being one getting into the G rated game . Unfortunately there is not a G rated tire made in the US with the 4000 lb rating or higher that I’m aware of . Big reason you are seeing these overseas tires showing up as OE on the new fifth wheels . I know the 2020 Bighorns come with the G rated Westlakes .
Michelle.S
Western NY till fall, then Sebring, FL
Posted: 08/13/20 07:50am Link  |  Print  |  Notify Moderator
Westlakes were being used on Redwoods and did do well, now they're using "Goodride" and so far don't sound any better, folks just see "Good" and thing they have Goodyear's till they fail.
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
Page of 7
 > Tires
