RV.Net Open Roads Forum: Dinghy Towing: Dinghy Towing
Search only in Dinghy Towing
 > Dinghy Towing
moondogcooter
California
Posted: 08/10/20 08:46am Link  |  Quote  |  Print  |  Notify Moderator
I'm buying a 2015 Honda Fit as a tow behind my Class A. I'm 30,000 lbs it's 2500 lbs do I need a braking system in the car? ...
Doug
wildmanbaker
Kennewick, Washington
Posted: 08/10/20 09:16am Link  |  Quote  |  Print  |  Notify Moderator
Only if it comes disconnected from your MH. In many states, a braking system is required over 1,500 pounds.
Wildmanbaker
camperdave
northern, California
Posted: 08/10/20 09:37am Link  |  Quote  |  Print  |  Notify Moderator
California (which it looks like you are in) requires brakes on any trailer over 1500 pounds. You could try to make the argument that a tow behind car is not a trailer, but not sure if that would work...
Personally I feel that if your total load with toad is under the GVWR of your motorhome, you would be fine since clearly the brakes are designed for that weight. Anything over GVWR, I'd want brakes on the trailer.
But that's just my rational opinion, and I doubt the CHP would agree lol.
All the braking companies would say yes, you do. But I've seen some compelling arguments relating to the wording of the CA law (with regards to whether a toad is a trailer, and also some wording about the law stating a required stopping distance as opposed to brakes or not. I don't know, but some googling would probably lead you down an interesting rabbit hole about it...
tldr: in California, yes you do. Most likely. [emoticon]
2004 Fleetwood Tioga 29v
enblethen
Moses Lake, WA
Posted: 08/10/20 09:53am Link  |  Quote  |  Print  |  Notify Moderator
Verify language. A towed motor vehicle is not a trailer in many states.
OP: what is make and model of MH?
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Bumpyroad
Virginia
Posted: 08/10/20 10:29am Link  |  Quote  |  Print  |  Notify Moderator
yes
IMHO it is foolish not to have one with out a break away system also.
bumpy
D.E.Bishop
Eagle Rock, CA
Posted: 08/10/20 11:05am Link  |  Quote  |  Print  |  Notify Moderator
MNC, I am a Californian and up until a couple of years ago did not have a SBS on my toweds, at that time the law on SBS'ss was a performance base law. Able to stop in X feet ax X speed, I went to the local CHP office where I had gotten a copy of the law and kept it in my RV, on my last visit, I was told the law had been changed and now towed vehicles were covered by trailer laws. I don't really feel that is true and the Chippy didn't have time to give me a copy of the law so I just put a SBS on my towed. Prior to my current GMC Canyon I had towed Suzis and didn't feel I needed extra braking, the Canyon is heavier than a Suzi and I can tell it.
I like stay in place systems but have a brake buddy now because I bought it really cheap at a close out sale.
So my answer is get it, it is cheaper than not being able to stop when you need to.
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
2002 Winnebago Adventurer 32V
Back to a 2006 Suzi GV
Roadmaster 5000
Roadmaster Invisibrake
howdy35
Athens, Texas
Posted: 08/10/20 11:40am Link  |  Quote  |  Print  |  Notify Moderator
You better check your owners manual to see if that car can be towed four wheels down. It was my thought that anything newer than a 2014 Honda could not be towed because of the CVT transmission. You may have a standard but you didn't say.
I pulled a 2000 Honda Accord behind a Bounder all over the Rocky Mountains back in 2002 without towed brakes or a Break-a-way system. I probably was fortunate to not have any problems. If I were doing it now, I would have some kind of braking system at least on the car. Happy travels. Arnold
* This post was edited 08/10/20 11:50am by howdy35 *
1999 National Tradewinds 7370
2014 Honda CR-V--Toad
Fulltime
way2roll
Wilmington NC
Posted: 08/10/20 11:48am Link  |  Quote  |  Print  |  Notify Moderator
howdy35 wrote:
You better check your owners manual to see if that car can be towed four wheels down. It was my thought that anything newer than a 2014 Honda could not be towed because of the CVT transmission. You may have a standard but you didn't say. Just trying to give more information to the topic. Happy travels. Arnold
I think you are right, there aren't any Honda's in the 2015 dinghy towing guide.
According to Remco if it's the 6 speed manual, it can be towed but not the CVT automatic.
ArchHoagland
Clovis, CA, USA
Posted: 08/10/20 11:52am Link  |  Quote  |  Print  |  Notify Moderator
moondogcooter....Is it an automatic?
If so you can only tow it on a trailer.
Remco
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
US Gear Brakes
Bishop area, California
Posted: 08/10/20 12:30pm Link  |  Quote  |  Print  |  Notify Moderator
"IMHO it is foolish not to have one with out a break away system also."
Absolutely foolish. Probably not dangerous for OP but is sure is for anyone behind him or driving in the opposite direction.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-parallel & MPPT, Trojan T-125s. TALL flag pole. Prefer USFS, COE, BLM, NPS, TVA, state & county camps. Bicyclist! 14 year Army vet-11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
 > Dinghy Towing
