RV.Net Open Roads Forum: Tech Issues: Toad Brakes; Permanent or Portable
 > Toad Brakes; Permanent or Portable
fwtraveler1
Posted: 08/11/20 08:29am Link  |  Quote  |  Print  |  Notify Moderator
Just purchased a 2020 Equinox as a toad for our first RV and would like input on which type of supplemental braking system to buy. We plan on at least 10 yrs with this toad.
w4phj
Vero Beach
Posted: 08/11/20 08:55am Link  |  Quote  |  Print  |  Notify Moderator
Having moved my Brake Buddy into my 3rd toad, I vote for portable.
2021 Winnebago View 24J
2014 Jeep Grand Cherokee Limited
2015 Jeep Wrangler Unlimited Sahara
Ham Radio Extra Class Volunteer Examiner
FAA A&P License
1969 Plymouth Road Runner
rk911
DuPage County
Posted: 08/11/20 09:02am Link  |  Quote  |  Print  |  Notify Moderator
we went with an installed unit in our jeeps. cleaner and less hassle when hooking up or disconnecting. plus no EZ place to store the device when not in use.
Rich
Ham Radio, Sport Pilot, Retired 9-1-1 Call Center Administrator
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
folivier
Southeast Louisiana
Posted: 08/11/20 09:35am Link  |  Quote  |  Print  |  Notify Moderator
Look at ReadyBrake, been using mine for over 8 years and it works great.
Bill/Diana
Southeastern Pennsylvania
Posted: 08/11/20 10:50am Link  |  Quote  |  Print  |  Notify Moderator
I use Brake Buddy that is 17 years old and working perfectly in our 2nd toad. There are advantages and disadvantages to portable and permanent systems. Setting up the Brake Buddy takes about 15 minutes and to removed it take 5 minutes. When at the campsite I sometimes just store the Brake Buddy in the back to the toad and other times place it in the basement of the motorhome. Brake Buddy also has great customer & tech support.
Once while on a trip the Brake Buddy wan't working properly. They sent a replacement loaner overnight delivery and I used the same packaging to return my defective unit. I continued to use the loader till they sent mine back the follow week. Repair cost was $100 and that was the only failure.
Bill & Diana
Please click here to visit our Website
Janss
Sedona, AZ
We have the SMI Stay-in-Play Duo installed on our toad. Simple operation...flip a toggle switch on and off. We also had this system uninstalled from old toad and installed on new toad.
2002 Itasca Suncruiser 32V
2012 Suzuki Grand Vitara
Bumpyroad
Virginia
Posted: 08/11/20 04:22pm Link  |  Quote  |  Print  |  Notify Moderator
same here, but no problems
bumpy
Wherever I happen to park
Posted: 08/12/20 05:22am Link  |  Quote  |  Print  |  Notify Moderator
Well I will talk about a few systems
Brake buddy and other box in the driver's seat systems
Good if you have a "Fleet" of towed's but.
You need to install them EVERY Time you tow. and every time you install it's a chance to mess it up.
Also for a short trip there is a strong temptation to say "To heck with it" and regret that decision later (Murphy's law says that is the trip you will wish you had put it in)
M&G This is an Air over Hydraulic system that is 100% under the hood. Noting in the cockpit on the car. 100% transparent to a driver.
IF it fits and your MH has air brakes.. Seriously consider it.
Next are electric over hydraulic. My first choice in this is the US-Gear Unified brake decelerator but there are many nearly as good. These mount in the cockpit but can be hard to see less you know what to look for
There are some versions of this that use compressed air but with electronic controls. (like the brake buddy) but are either installed or half installed
Finally there is the Ready Brake. (my next braking system) this is a surge brake system. 100% mechanical as the car pushes against the MH the brakes are applied. Blue Ox also sells a competing product.
Advantage all of the above With a couple of exceptions all you do is plug it in 2 seconds and it's live. Those exceptions are the ready brake and comptitor where you clip the clip to the cable (ALso a 2 second job) and one where all you do is pulg in the Tow Light Plug. it draws power off the tail light line and control off the turn/brake leads.
Home is where I park it.
Bumpyroad
Virginia
Posted: 08/12/20 06:17am Link  |  Quote  |  Print  |  Notify Moderator
no "Fleet" of cars needed. I used my Brake Buddy in three different toads. didn't need an expensive installation when I changed them.
bumpy
travisc
Pacific NW
Posted: 08/12/20 06:42am Link  |  Quote  |  Print  |  Notify Moderator
I did ready brake for 8 years, and installed two demo/ sim stay and plays last year, you turn them on and they are ready to go, nothing to take out and store some where
Winnebago Access 24V
