RV.Net Open Roads Forum: Class A Motorhomes: Handling issues 2005 Fleetwood Expedition 34H
 > Handling issues 2005 Fleetwood Expedition 34H
Gundog
Ridgefield, Wa
Posted: 08/11/20 07:24pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2005 Fleetwood Expedition 34H. This is a diesel pusher with a Cat C7 and a Freightliner chassis. I purchased this coach about 18 months ago from a private party. The tires that were on it were original (Michelin)and I was afraid to drive it with tires that old so I took it straight to the tire shop before driving it the 2 hours home.
I made the tire order before picking it up so they would have the tires on hand. I had a choice between Firestone and Michelin the Michelin tires were $1500 more than the Firestone so I chose the Firestone.
The issue I am having is the coach wanders and requires a constant steering correction to stay in your lane you can't take your eyes away to hardly look into the rear view mirror with departing your lane. I have a commercial drivers license so I am not new to driving large vehicles.
The Firestone tires are FS 561 275/70R22.5 they are maximum tire pressure 130 PSI. The fronts had 95 PSI in them and the rear tires had 105 PSI in them. They tried inflating them to 120 PSI front and 110 in the rear but that did not make it better.
I ran the coach over the scales and I have 7500# on the front axle and 16240# on the rear axle.
Monday I have an appointment to have the front end aligned. The tire shop has offered to exchange the tires for the Michelin tires but I will have to pay the upgraded price. I am happy they are offering to do that Bottom line I am just trying to get this thing to handle properly I will pay to upgrade the tires if that will make it better.
I tried to contact Firestone to get a recommended tire pressure but they never responded to my email.
Can anyone add any good info for me?
Thanks Mike
2005 34' Expedition Cat C7 Allison 3000
garyemunson
Reno, Nevada
Posted: 08/11/20 08:12pm Link  |  Quote  |  Print  |  Notify Moderator
My guess the alignment shop will find too much toe-out, maybe worn parts. Firestone makes good tires, it's not them. Miles on the coach?
Gundog
Ridgefield, Wa
Posted: 08/11/20 08:15pm Link  |  Quote  |  Print  |  Notify Moderator
It is possible but I don't think the parts should be worn too much it has 38,655 miles on it. I am hoping the alignment will help. I am not sold on it being the tires.
* This post was edited 08/11/20 10:20pm by Gundog *
MountainAir05
New Mexico
Posted: 08/11/20 09:20pm Link  |  Quote  |  Print  |  Notify Moderator
I think you have too much air pressure along with Alignment check.
Gundog
Ridgefield, Wa
Posted: 08/11/20 10:07pm Link  |  Quote  |  Print  |  Notify Moderator
How much do you run in yours?
down home
south
Posted: 08/11/20 10:49pm Link  |  Quote  |  Print  |  Notify Moderator
We had our revolution aligned several expensive times. One in Missouri they even bent the front axle straight... Finally, at the factory they checked thing out and...the rear axle, right side I think was maybe an inch forward of the other side on the frame. They loosened bot sides aligned the axles perpendicular to the frame and welded in spacers/washers. It steers much much better. That was probably 8 years ago. Also those rubber sway bar links were chewed up. They replaced them.
last week I finally got polyurathane sway bar bushings installed.Shocks contribute greatly to all the handling ills. Had them replaced last week too.
A rear sway bar is next. I thought it had one but it doesn't.
craig7h
Branson MO area
Posted: 08/12/20 03:32am Link  |  Quote  |  Print  |  Notify Moderator
I bought my 07 Itasca Meridian with 380000 miles on it last year. I have the same cat c7 on a freightliner frame with michelin tires. When I first got the coach I took it to a trusted chassis shop to go over everything related to the chassis. While greasing the front steering zerks they noticed the front wheel bearings were not good. Point is make sure all of your frame components are in good working order before working on the tires. My coach runs straight and true with 95-100 psi in front and 100 psi rear.
Itasca Meridian SE 36g
Road Master Tow Dolly
dodge guy
Bartlett IL
Posted: 08/12/20 05:45am Link  |  Quote  |  Print  |  Notify Moderator
How was the MH driving before the tires? If you didn't have the problem before en it's in the tires. I personally don't like Firestones, and I like Michelins even less, but with these sizes you don't have much choice in brand. I know Firestones have a tendenacy to pull, but that's in car and LT tires.
Let us know what the alignment shows.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
w4phj
Vero Beach
Posted: 08/12/20 06:03am Link  |  Quote  |  Print  |  Notify Moderator
I run my Michelin's 275 70 22.5 at 90psi since they are oversize for the coach. Drives like a dream. Tire footprint is critical.
2005 Bounder 37U Cat C7 Engine
2014 Jeep Grand Cherokee Limited
2015 Jeep Wrangler Unlimited Sahara
Ham Radio Extra Class Volunteer Examiner
FAA A&P License
1969 Plymouth Road Runner
IB853347201
Eastern Ontario
Posted: 08/12/20 06:26am Link  |  Quote  |  Print  |  Notify Moderator
I agree, too much air pressure in the tires. The manufacturers specified inflation will be on a placard next to the drivers seat on the wall below the drivers side window. Set your tires to whatever the manufacturer recommends and see if this solves your issue.
Touring in our 2010 Suncruiser, beaches, site seeing, national parks, chillaxing..
