RV.Net Open Roads Forum: Tow Vehicles: Carelessness strikes again
Search only in Tow Vehicles
 > Carelessness strikes again
Mote
Hoosier State
Posted: 08/13/20 06:46am Link  |  Quote  |  Print  |  Notify Moderator
Been there, done that. To my son's car a few years back. He called said the car would only move in reverse. I assumed the transmission was bad as it was an old beater. I borrowed a trailer. Took a three hours round trip to pick it up and bring it home.
I worked hard jacking up the car to get it off the trailer. Was quite surprised once I finally got it on the jacks and found out my error.
2005 Dodge 3500
2001 Lance 1030
2006 Cougar 29RL
DarkSkySeeker
Freestone, California
Posted: 08/13/20 07:57am Link  |  Quote  |  Print  |  Notify Moderator
agesilaus wrote:
...being of the packrat tribe I had saved a bolt from the the last time, in my bolt box...
That is always a good feeling.
There is something special about camping in an RV.
schlep1967
Harrisburg, PA
Posted: 08/13/20 08:05am Link  |  Quote  |  Print  |  Notify Moderator
Unless you actually put new caliper bolts in the last time ..... How could you have an extra to save?
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
agesilaus
North Florida
Posted: 08/13/20 08:14am Link  |  Quote  |  Print  |  Notify Moderator
Last time I replaced the caliper
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
Mike LeClair
Wetaskiwin, Alberta
Posted: 08/13/20 10:28pm Link  |  Quote  |  Print  |  Notify Moderator
Cliff hanger alert!! or am I missing something? What was the error?
Cheers!
Mike
Something Old, Something New
2012 F350 SRW, 6.7l Powerstroke, 3.55's front and rear.
2008 Fleetwood Regal 325RKTS
Mike, Carol and our 4 legged "furry child" Kenzie Shweenie Tod
memtb
Wyoming
Posted: 08/14/20 07:55am Link  |  Quote  |  Print  |  Notify Moderator
This is sorta an ongoing saga with me. I’ve got so many different projects going or need to be started....I’m often working on one, while thinking of another! I can’t multi-task.....mentally or physically! memtb
Todd & Marianne
Miniature Schnauzer's - Sundai, Nellie & Maggie Mae
2007 Dodge Ram 3500, 6.7 Cummins, 6 speed manual, 3.73 ratio, 4x4
2004 Teton Grand Freedom, 39'
2007 Bigfoot 30MH26Sl
Thunderbolt
North Branch, Mn USA
Posted: 08/14/20 08:12am Link  |  Quote  |  Print  |  Notify Moderator
I haven't done that, but I did replace the engine in a truck once and had all the bell housing and motor mounts in. I happened to walk to the passenger side and there was the flex plate sitting on the floor.
Bryan
2003 2500HD Ext. cab short box
6.0 liter 4.10 gears, Nelson performance PCM
98 K1500 4x4 heavy duty 1/2 ton
6,600lb GVWR 5,280lbs on the scale empty
14 bolt rear diff. 3:73 , Tranny and oil coolers
371,000 miles still purrin' like a kitten
mudfuel07
North Florida!
Posted: 08/14/20 09:25am Link  |  Quote  |  Print  |  Notify Moderator
Done the exact same thing, but I wasn't as lucky. I did put both caliper bolts in, but the tires vibrated one loose. It happened when I was about 15 miles from home, I thought maybe I could limp it back, the caliper rubbed a hole in the rim, tire went flat and I barely got it off the road. Being stubborn, I did make it home. It only cost me one new 37" tire and 4 rims since they quit making the ones that I had anymore. You can bet I put locktite on all components now.
2017 Ram 2500 6.7 CTD 4x4 SLT
2020 Puma by Palomino 32RBFQ for the kids!
Posted: 08/14/20 11:47am Link  |  Quote  |  Print  |  Notify Moderator
^ I can relate! Lol
But I don’t like loctite on anything that doesn’t require it, unless it’s a bandaid for an issue that isn’t normal.
Maybe that’s because of my upbringing in the rust belt where most bolts would self loctite after 1 winter anyway and by year 5 they seemed to be welded in!
Brake caliper bolts are the first thing I put anti seize on....them and the
lug nutz.
* This post was edited 08/14/20 01:00pm by Grit dog *
agesilaus
North Florida
Posted: 08/14/20 01:21pm Link  |  Quote  |  Print  |  Notify Moderator
I was thinking about that, I have a tube of the blue in my toolbox.
