RV.Net Open Roads Forum: Class A Motorhomes: Onan exhaust hangers don’t last
 > Onan exhaust hangers don’t last
ford truck guy
Pennsylvania
Posted: 08/14/20 12:27pm Link  |  Quote  |  Print  |  Notify Moderator
Chum lee wrote:
MountainAir05 wrote:
My first one last about 5 years. The replacement came from a auto parts store and its been on there 15 years. It looks like maybe a tire type laminated material. Without some flex you going to get breakage on metal to metal connectors.
Yes! There are better grades of reinforced rubber. I just found a failed tire (blowout) and cut the appropriate sized rubber strip out of the sidewall. You need a sharp knife to do that. Drilled out the rivet and drilled two holes in the rubber strip and replaced it with an appropriate sized bolt and nut Problem solved for free. It's been fine now for 7 years.
Chum lee
I like that idea Chum Lee.. easy and effective
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
dougrainer
Carrolton, Texas
Posted: 08/14/20 01:37pm Link  |  Quote  |  Print  |  Notify Moderator
Hangers usually FAIL because they are NOT installed correctly. Exhaust hangers just support the tail Pipe. If, when you install you are putting a load on the hanger, the Rubber will fail. AFTERMARKET Hangers (Auto supply stores) are much better grade. Sometimes, you may need 2 depending on how long the Tail Pipe is. Doug
camperdave
northern, California
Posted: 08/14/20 02:14pm Link  |  Quote  |  Print  |  Notify Moderator
Mine broke last year, I replaced it with something that looked close enough that I found at the local auto parts store.
In my case, the end of the Onan exhaust pipe went through a metal hoop that was screwed onto the bottom of the motorhome. When the support broke, the pipe sprung a bit was now firmly pressed against the hoop. Obviously the rubber support had been under a lot of stress for many years. I removed the hoop, let the pipe self settle where it wanted to be naturally, then mounted the new hanger in a stress free manner. I don't expect it to ever break again.
2004 Fleetwood Tioga 29v
Chum lee
Albuquerque, NM
Posted: 08/14/20 09:04pm Link  |  Quote  |  Print  |  Notify Moderator
Chum lee
Thank you. It's my lifes work.
ezgoin
Sunny Arizona
Posted: 08/17/20 11:26am Link  |  Quote  |  Print  |  Notify Moderator
dougrainer wrote:
Hangers usually FAIL because they are NOT installed correctly. If, when you install you are putting a load on the hanger, the Rubber will fail. AFTERMARKET Hangers (Auto supply stores) are much better grade. Sometimes, you may need 2 depending on how long the Tail Pipe is. Doug
Isn’t the intent of the hangers to support the weight of the genny exhaust? I currently have 2 completely broken, with another one attached near the engine exhaust that is ready to break.
Bill
The older I get....the better I was.
Bill & Terry
And our canine kids, Skippy & Peanut
2014 Fleetwood Bounder Classic 30T
2016 Jeep Wrangler Unlimited Toad
Chum lee
Albuquerque, NM
Posted: 08/18/20 05:37pm Link  |  Quote  |  Print  |  Notify Moderator
Bill
Watch the genny when it operates. Just like the main engine, it bounces around quite a bit. You need to have the flexible mounts on the exhaust system absorb that flex while supporting the weight. Then there's the expansion/contraction due to the thermal cycles too.
Chum lee
