RV.Net Open Roads Forum: Tech Issues: Dish Network Satellite Question
 > Dish Network Satellite Question
Posted: 08/17/20 01:07pm Link  |  Quote  |  Print  |  Notify Moderator
Bill.Satellite wrote:
if you have a dual tuner receiver like the 322 you can power both tuners with a single coax and the correct splitter...
This is exactly what I'm trying to do. I have the original DPP splitter used when this 322 receiver serviced my home. I ordered a new one and am waiting for it to be delivered. What I'm calling a splitter is a Triplexer part number 175284.
I'm under the impression that my setup isn't working because my dish LNB is not a "Dish Pro Plus" LNB
And I'm sure it's obvious why my handle is not "2112.satellite". I'm clueless to this voodoo magic stuff [emoticon]
2013 KZ Durango 2857
TechWriter
On The Road
Posted: 08/17/20 03:38pm Link  |  Quote  |  Print  |  Notify Moderator
You can power ONE receiver with ONE coax. However, if you have a dual tuner receiver like the 322 you can power both tuners with a single coax and the correct splitter.
Like so . . .
2001 Newmar Mountain Aire 4095 DP
Full Timer since May 2013
www.rvSeniorMoments.com
DISH TV for RVs
TechWriter
On The Road
Posted: 08/17/20 04:03pm Link  |  Quote  |  Print  |  Notify Moderator
If you're currently using a Winegard GM-MP1, then, yes, I believe it uses a single LNBF that's not a DPP.
About your other sat dish . . . the 1000 w/o an LNBF. Throw it out. Not worth trying to upgrade. Even if you do, you'll end up with a triple-LNBF which can be difficult to aim . . . especially if you're used to just pointing that MP1.
I suggest getting an old Dish 500 twin LNBF dish. Easier to aim than a triple LNBF dish and gets sats 110 & 119 (or 119 & 129 if you mis-aim) . . . and a Dish 500 will support two receivers . . . like so:
Posted: 08/18/20 04:41am Link  |  Quote  |  Print  |  Notify Moderator
Thanks TechWriter
The second illustration, without the UHF/VHF diplexer, is what I'm trying to do. I am using the GM-MP1, and that is why it doesn't work.
I agree with not trying to rebuild my old dish. The 500 you pointed me to is about $20 more than the price I would pay to rebuild mine. I'll toss it back in the barn.
In conclusion, I now know why it doesn't work and what to do to make it work. Dish Network was correct in saying it won't work and "THEY" do not sell compatible components to solve my issue. All they wanted to do is upgrade me to Hopper/Joey.
Thanks to everyone for your help
Bill.Satellite
Full-timer
Posted: 08/18/20 07:01am Link  |  Quote  |  Print  |  Notify Moderator
Right. Each BOX (receiver) needs its own coax but 1 box with 2 tuners only requires 1 coax and the splitter.
What I post is my 2 cents and nothing more. Please don't read anything into my post that's not there. If you disagree, that's OK.
Can't we all just get along?
