RV.Net Open Roads Forum: Non Slip shower floor
DD716TED
Washington State
Posted: 08/13/20 04:13pm Link  |  Quote  |  Print  |  Notify Moderator
We have a fiberglass shower enclosure in the trailer however the bottom is almost smooth with no tread moulded in. To prevent slippage, I have tried several shower mats but they slide and have also tried the non-skid stick down white rubber non skid strips available at HD. After preping and cleaning the shower surfce as directed.. THEY TO come loose.. anuone found a stick down type of shower tread that will work as advertised?
dhull
apple valley
Posted: 08/13/20 04:27pm Link  |  Quote  |  Print  |  Notify Moderator
Have you tried the mats that have little suction cups on them?
Lone Pine, CA
Posted: 08/13/20 04:50pm Link  |  Quote  |  Print  |  Notify Moderator
They to came loose? Very unusual. My cheapo from Big Lots works great.
Bumpyroad
Virginia
Posted: 08/13/20 04:51pm Link  |  Quote  |  Print  |  Notify Moderator
yep, I use them in my fiberglass tub/showers in my S&B, $1.80 at walmart.
bumpy
Dutch_12078
Winters south, summers north
Posted: 08/13/20 06:47pm Link  |  Quote  |  Print  |  Notify Moderator
I used white stick on non-skid strips from Walmart that have been in place for about 3 years with no signs of loosening up yet. After cleaning with a tub cleaner, I went over the area with alcohol wipes before applying the strips.
Dutch
2001 GBM Landau 34' Class A
mobeewan
Hampton, Va
Posted: 08/13/20 11:51pm Link  |  Quote  |  Print  |  Notify Moderator
I use white plastic soft vinyl shelf liner that comes on I believe it is a 24 inch wide roll. It is like the spongy nonskid shelf liner with the square holes in it used to keep dishes from sliding around. It felt a little weird standing on it at first, but I got used to it and stopped noticing it. I cut mine about 24 x 16 or 18.
The only problem was that although being solid vinyl and it does not soak up water, water did get trapped under it, so I had to hang it to drip dry or stuff would start growing under it. When it does need cleaning I lay it in the tub and scrub it with a soft bristled brush with a little Dawn or clean it with Soft Scub with Bleach when I clean the tub and walls.
Bumpyroad
Virginia
Posted: 08/14/20 05:57am Link  |  Quote  |  Print  |  Notify Moderator
that reminds me, some of the vinyl mats I looked at were able to be tossed into the clothes washer. but at $1.80, why bother? but I haven't seen them post covid.
bumpy
Sjm9911
New Jersey
Posted: 08/14/20 07:30am Link  |  Quote  |  Print  |  Notify Moderator
They sell a clear sray paint product that adds grip. I dont know if its safe for the shower pans, but take a look.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
johnhicks
Wandering below the Gnat Line
Posted: 08/14/20 09:49am Link  |  Quote  |  Print  |  Notify Moderator
Krylon Non-Skid spray paint, #3400 Clear
-jbh-
