RV.Net Open Roads Forum: Towing: tire psi
Search only in Towing
Open Roads Forum  >  Towing
 > tire psi
jimcatinmi
michigan
Posted: 08/14/20 05:58am Link  |  Quote  |  Print  |  Notify Moderator
good morning, I just switched from a tt to a 5th wheel and I noticed when hooked up my tires look a little low. Should I set the psi to what the tire says or what's on the door?
2014 F150 5.0 coyote
Flowmaster Cat back
2006 Laredo 29RK
Pullrite superglide 16k
Monroe Load Assist
eHoefler
ozark mountains
Posted: 08/14/20 06:33am Link  |  Quote  |  Print  |  Notify Moderator
What is listed on the tire
2019 Ram Limited, 3500, Crew Cab, 1000FTPD of Torgue!, Max Tow, Long bed, 4 x 4, Dually,
2006 40' Landmark Mt. Rushmore
cougar28
Lowell,AR USA
Posted: 08/14/20 06:58am Link  |  Quote  |  Print  |  Notify Moderator
To what the tire says. Also make sure there rated for the weight your put on them. White the 5er in your sig I would say your put around 1500 to 1600lb in the bed.
2002 F-250 SD CC 7.3PSD Auto. XLT Short Bed 4X4 Off-Rd.Pkg.Highland Green,Westin Sportsman Grille Guard (Black) RBW Li'l Rocker Slider ,Prodigy Control Towing Jayco Eagle HT 30.5 MLOK,Handy 5er tailgate
12th Man Fan
Flower Mound , Texas
Posted: 08/14/20 07:51am Link  |  Quote  |  Print  |  Notify Moderator
The sticker on your door reflects the inflation for max. GWR of your truck. That is the info I use to inflate my tires. There is no use going higher unless you are overloading the truck.
2014 GMC Duramax 4X4 DRW Crew
2015 DRV Tradition
cougar28
Lowell,AR USA
Posted: 08/14/20 07:57am Link  |  Quote  |  Print  |  Notify Moderator
But what if the tires is not factory? Did some put lighter on it at some point- maybe heavier ply tires.
MFL
Midwest
Posted: 08/14/20 08:03am Link  |  Quote  |  Print  |  Notify Moderator
Wow, if that FW is hooked up to your F150 and using a heavy Superglide slider, you will need the max tire pressure on the sidewall! What is your RAWR/tire max rating?
That is a nice looking rig, but certainly at truck's limit.
I would add a few lbs to front tires also, even though most all FW weight is carried by the rear.
Jerry
* This post was edited 08/14/20 08:11am by MFL *
jimcatinmi
michigan
Posted: 08/14/20 08:28am Link  |  Quote  |  Print  |  Notify Moderator
Thanks so much for the info, yes we are at the limit for the truck I did put Monroe load assist shocks on the rear and that did help. the pin weight is 1400lb but that's not loaded. I will look at the tires for the numbers when I get home but I do know its a Michelin LT tire.
Desert Captain
Tucson
Posted: 08/14/20 08:33am Link  |  Quote  |  Print  |  Notify Moderator
Get your rig weighed as it will be used and then check the load inflation chart from the tire manufacturer and inflate accordingly.
[emoticon]
jdc1
Rescue, Ca
Posted: 08/14/20 09:15am Link  |  Quote  |  Print  |  Notify Moderator
Before you add propane, water, gear, hitch and PEOPLE......you only have 300 pounds of capacity left.
Lone Pine, CA weather permitting
Posted: 08/14/20 09:36am Link  |  Quote  |  Print  |  Notify Moderator
Water alone, JDC1,....
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-parallel & MPPT, Trojan T-125s. TALL flag pole. Prefer USFS, COE, BLM, NPS, TVA, state & county camps. Bicyclist! 14 year Army vet-11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
 > tire psi
