NVR2L82AV8
Las Vegas
After a good washing yesterday I got up early (while the camper is in the shade and the temp has not exceeded 100--yet) to put a good coat of Meguiar's Marine/RV one step Cleaner Wax on. I'm a huge fan of Aerospace 303 and use that in-between full waxes. I think it has made a huge difference in keeping the gel coat shiny.
Here's a pic of my nose cap half waxed and half not waxed. Where its parked during non-use the Nose Cap and roof gets the most sunlight.
![[image]](https://i.imgur.com/grHHD1Zl.jpg)
I was pleased with the contamination that came off the gel coat. I still have some strong bug marks but overall it looks great - all finished and polished! The decals are showing their age! In the heat of the hot summers I get small ripples at the top of the cap. Anyone seen that before?
2013 AF 990
2003 F350 6.0L 4X4 DRW, Oil bypass filter, Coolant Filter, Blue Spring fuel pressure mod, DELO ELC, DashBoss Bluetooth engine monitor, EGT/FP gauge, SuperSprings, torklift hitch/tiedowns, 48" SuperTruss, fastguns, Kenwood CMOS Backup Camera.
Lake Crowley area, California
Looks good!
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-parallel & MPPT, Trojan T-125s. TALL flag pole. Prefer USFS, COE, BLM, NPS, TVA, state & county camps. Bicyclist! 14 year Army vet-11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
Oregun
Oregon
Our RV air conditioner stopped working. Blowing warm air, but I could tell the compressor would try to startup for a second or two. Got on the roof and measured the 5/50 startup capacitor. Fan side measured 5uf , compressor side measured 1.5uf instead of 50uf. Found a replacement part on ebay for $20. Must be lot of them failing since lots of places were out of stock. Put the new one in today and it works great.
specta
utah
Stocked it with food.
Kenny
2011 Chevy 2500 HD 6.0L 4wd
ppine
Northern Nevada
Slept in in it again in my backyard campground.
JimBollman
Lost State of Franklin
Filled up with alcohol free gas so it wouldn't go bad before I could use it up. First fill up since March. Probably will dump some stabilizer in too. We use it as a second vehicle so it does get a few miles put on most weeks.
routeforty
ohio
Checked and aired up the tires, drove to propane dealer and filled the propane. Getting ready to take grandson to Texas next week for college. Praying that the weather will be cooler then than it is now-107 around Ft Worth today-not much fun when it's that hot.
2018 coachmen leprechaun class c
fpoole
PNW and Beyond
Traveling to CO, for a SxS rally...
Frank Poole
Roam'n ROG (Full Timer since Oct '15)
2016 RAM 5500, C/c, 6.7 Diesel, AISIN HD 6-spd, 19.5 DRW, 72 Gal fuel, 4x4, 10ā Alum FB, 440 Amps, 4.10 Axle
2016 AF 990 640-Solar/10-6v Batts
GlowStep Stow Nā Go, E-Bike
RS1 Buggy
frank
Pooles website
K Charles
Connecticut
Put a set of brake pads on the front, plus it needed one caliper and one hose. I didn't do it all in one day 'cause 22.5 tires get heave when your over 70 and it's hot.
JimK-NY
NY
Strange. I actually did something today. I started up the generator and set the charger to 14.3 volts and let it run for a half hour or so.
