RV.Net Open Roads Forum: What did you do to your Camper Today?
 > What did you do to your Camper Today?
Page of 13
Freep
Wisconsin
Posted: 09/01/20 04:19pm Link  |  Quote  |  Print  |  Notify Moderator
I pulled the battery, then removed the battery compartment door and the plastic battery compartment. I upgraded to LiFePo4 a few months ago and I don't need to keep the battery separate from the cabin air and I need the space to install an inverter.
Rewiring the compartment is next.
2014 Lance 992
2014 Ram 3500 DRW Turbo diesel
Seminoe Joe
Texas, Wyoming, or somewhere in between
Posted: 09/01/20 05:59pm Link  |  Quote  |  Print  |  Notify Moderator
Replaced some dead bulbs in the rear running lights.
“It’s all in the reflexes.”
2012 Lance 850
2012 Chevy 2500 HD
Seminoe Joe
Posted: 09/11/20 09:48am Link  |  Quote  |  Print  |  Notify Moderator
Flushed and rinsed the freshwater tank and grey water and will let it sit with a vinegar solution to clear out the bleach scent and flavor. Draining that and filling it up Sunday to depart Monday.
thedavidzoo
Tucson, AZ
Posted: 09/11/20 09:15pm Link  |  Quote  |  Print  |  Notify Moderator
Rewired a bunch of stuff throughout the TC so I can run all 110 sockets and select appliances off my inverter while keeping 12V stuff supplied from the lithium batteries.
Fitting and wiring the relay in when you are out of space in the battery/solar/inverter box was a pain. Had to re-lug some cables and move some terminals.
Snaking the 110V wire in and out of the underbelly from inverter to transfer switch/converter was relatively easy given that our TC doesn't have a traditional enclosed and skinned bottom.
I also added a relay to shut down solar charging just in case of overvoltage on any of the 16 battery cells.
Next up, where to store a gun/valuables safe...
2014 Ram 3500 CrewCab Diesel DRW 4x4 4.10 Aisin, Torklift Fastguns, Upper Stableloads, Timbrens
2017 Northstar 12' STC
640W solar, 400Ah lithium LiFeMnPO4 batteries
specta
utah
Posted: 09/12/20 06:26am Link  |  Quote  |  Print  |  Notify Moderator
I drained the water heater. LOL
Kenny
2011 Chevy 2500 HD 6.0L 4wd
6580 lb truck 10540 fully loaded
jaycocreek
Idaho
Posted: 09/12/20 11:37am Link  |  Quote  |  Print  |  Notify Moderator
Took the Lance steps off and got a cheap, more wife and doggie friendly step..
1994 F-350 DRW /460/k&n intake /415# torque/lance 9.6/Engel compressor fridge/3 gr 27 batteries/Honda 2k/Honda 3K/WH Camo 2250/Reese solid bar extension/Buddy heater/3 inverters//Happi Jack tie downs /Firestone bags/Yamaha Rhino/Winch and Lockers
Freep
Wisconsin
Posted: 09/21/20 03:04pm Link  |  Quote  |  Print  |  Notify Moderator
Today I tested the battery and inverter by running the air conditioner and the microwave at the same time. It works!
specta
utah
Posted: 09/24/20 05:40pm Link  |  Quote  |  Print  |  Notify Moderator
I hunted forever for one of those Lance steps and could never find one.
I guy in the Lance Camper forum gave me his and shipped it to me for free. The shipping was $76 alone.
There are tons of awesome people out there in the world today.
specta
utah
Posted: 09/24/20 05:47pm Link  |  Quote  |  Print  |  Notify Moderator
I unloaded it off my truck and let half the air out of my tires. [emoticon]
That's the first time its been off since I loaded it back on March 15th.
I had to unload it so I can make a 400 mile round trip to get two sheets of plywood. LOL
thedavidzoo
Tucson, AZ
Posted: 09/24/20 08:27pm Link  |  Quote  |  Print  |  Notify Moderator
Lubed all Dometic window struts and tracks with silicone stuff and wiped window trim and other exterior camper plastic parts with a pricey UV protectant. Used it on all the black plastic on the truck exterior also while I was at it. Wow, looks much better now.
Page of 13
