JoeChiOhki
Sauvie Island, OR
AnEv942 wrote: Added umbilical cord caps, made hangers so cords hang vertically
Recently had issue with corrosion again on auxiliary umbilical cord.
(2nd umbilical cord- back up camera, refer control & aux. charge line, AC cord to run refer on trucks inverter)
Though usually bungied up under camper they are exposed to the air can and do corrode. After cleaning
I looked at how to avoid this I stumbled on cord caps, I was unaware these could be had.
![[image]](https://photos.smugmug.com/AnEv942/ACinvert/i-txVnRsp/0/d4ce6a6d/O/cordprotk6.jpg)
Issue though if cord is simply hung caps can fill with water and corrosion will be worse so cords need to
hang vertically with cap up.
I simply bent up some scrap 2" aluminum flat bar, Drilled hole cut slot to capture cords.
Drilled for mounting and bent the tips up a bit.
As umbilcal cords are stiff had to mount hangers at angle. Bedded in caulk and screwed to wall.
Caps should minimize future corrosion, hung against camper wall so wont need to stop when
loading/unloading to reposition cords, easy retrieval to plug in once camper loaded.
![[image]](https://photos.smugmug.com/AnEv942/ACinvert/i-x72xmJs/0/b08d9491/O/cordprotk5.jpg)
Likely other brands-just what I used
Very nice . What made you decide to keep the umbilical cables as attached cables vs adding plugs on the camper, allow for the cable to be completely removed and stored when not in use?
My Blog - The Journey of the Redneck Express
CB Channel 17 Redneck Express
'2006 Heartland BigHorn 3400RL
jaycocreek
Idaho
942..Nice
I put a thermometer in my Engel compressor fridge/freezer and against my Lifepo4 batteries so I can read them at a glance and not wonder what either temp is
Lifepo4-380ah/Lithium NMC-140ah/Solar-400 watts/Wagan & Giandel PSW/Engel & Iceco 3-1 compressor fridge freezer/5K Window AC/Honda 2K
AnEv942
CA
JoeChiOhki wrote:
Very nice ![smile [emoticon]](http://www.rv.net/sharedcontent/cfb/images/smile.gif) . What made you decide to keep the umbilical cables as attached cables vs adding plugs on the camper, allow for the cable to be completely removed and stored when not in use?
Mostly expense plus finding a place to store (and the time involved
Though I could justify changing out the shore cord
Our camper projects page
deltabravo
Spokane, WA
I installed some sound deadening material in my generator compartment:
Noico Sound deadening mat in gen compartment
I found the mat on Amazon
deltabravo
Spokane, WA
What happened to your display monitor? It needs a thorough cleaning.
jaycocreek wrote: I put a thermometer in my Engel compressor
![[image]](https://i.imgur.com/bIMnMGo.jpg)
deltabravo
Spokane, WA
Installed a Victron Energy Orion-Tr Smart 12/12-Volt 30 amp 360-Watt DC-DC Charger behind the drawers in my AF 992
Here's the details.
And here's the details on the heavy gauge wiring from the truck to the camper
Ramblin' Ralph
Central California Coast
I travel solo, so having a Net connection at a campsite gives me something else to do. To increase the chance of having a cell Net connection in the boonies, I installed a weBoost cell booster system. Confirmed it does increase the strength via my phone "bar meter", but haven't had a chance to get a dBm reading yet.
Photos are:
1) Booster antenna in the up position when at a campsite
2) Antenna at the down position when traveling or exiting a woody campsite
3) Inside electronics hookup. Kit came with longer cables than I need, so the excess is hidden behind the seat cushions. I only had one cig lighter output where I wanted to install the system, that I plugged a USB charger into. So, I installed a device with multiple 12v and USB outputs.
Will be hitting the road in early June for several months, so the booster will get plenty of use. ![smile [emoticon]](http://www.rv.net/sharedcontent/cfb/images/smile.gif)
![[image]](https://hogtimemusic.com/nomad/miscphotos/InstalledUp.jpeg)
![[image]](https://hogtimemusic.com/nomad/miscphotos/InstalledDown2.jpeg)
Ralph
2006 GMC 2500HD, XCab, SB, 6.0L w/2001 Lance 845
Bilstein Shocks, TorkLift Stable Loads, 100 Ah LiFePo4, 225 watt solar
My RV Travels Webpage / Yearly Campsite Map / 740 Campsites / YouTube Videos /
Instagram
ticki2
NH
Ralph , I hope you report back with your findings once you have had a chance to use them
'68 Avion C-11
'02 GMC DRW D/A flatbed
jaycocreek
Idaho
Ralph...I have two of the old trucker Wilson 50 dbm boosters..I was going to parralel them but gave up..One does quite well,,,The antenna used is very important..I have Yagi for when parked for long times and a small magnetic for other times..
Nice setup
timdan94
pa
added 2- 195 watt solar panels in series mounted on the roof rack via strut, added a 100 watt panel in series with the existing 100 watt factory panel, tied both series panel strings in parallel, installed a Victron 100/50 MPPT solar charge controller. put a 30 amp breaker between the solar panels and the Victron charge controller, ran new 6 gauge wire between the charge controller and batteries, installed a 50 amp breaker between the batteries and the charge controller.
![[image]](https://scontent-iad3-1.xx.fbcdn.net/v/t39.30808-6/279141255_10101450301127432_5830284201407971274_n.jpg?_nc_cat=102&ccb=1-5&_nc_sid=8bfeb9&_nc_ohc=o3bJdI1EA9QAX8idGW4&_nc_ht=scontent-iad3-1.xx&oh=00_AT9XU4IqRPExXd07xDLkUV0h21hPklrkLtYWbfKZtip2gw&oe=626B8C46)
![[image]](https://scontent-iad3-1.xx.fbcdn.net/v/t39.30808-6/278690330_10101450301092502_5772872012083619698_n.jpg?_nc_cat=102&ccb=1-5&_nc_sid=8bfeb9&_nc_ohc=Nw1LTi0kbOgAX87-TNR&_nc_ht=scontent-iad3-1.xx&oh=00_AT8eTZ14F8dRdD4nORnqj7zXRFTwPCIlyKumV73XMWGt5A&oe=626B91C9)
![[image]](https://scontent-iad3-1.xx.fbcdn.net/v/t39.30808-6/278916023_10101450301162362_5671520990130798572_n.jpg?_nc_cat=107&ccb=1-5&_nc_sid=8bfeb9&_nc_ohc=wa3Mm08uVNkAX-iyHjC&tn=7D73MkRjz3ul7U9_&_nc_ht=scontent-iad3-1.xx&oh=00_AT__XgLSWHnmVY8eqqu4D5zAtBOgLb00oj1botG9cDSyXg&oe=626CC6C3)
edited 04/26/22 03:58pm by an administrator/moderator *
