RV.Net Open Roads Forum: Fifth-Wheels: Pin Box with Air
 > Pin Box with Air
ACZL
UPstate,NY
Posted: 08/16/20 08:52am Link  |  Quote  |  Print  |  Notify Moderator
Rob,
I too have the B&W Patriot along w/ the 5th AirBourne pin box. I, like others, air it up and don't touch it for rest of season except to top off once in awhile. Like others as well, I make sure there is some weight going onto the B&W (doesn't need to be a lot) when hooking up and never have had a problem. When unhooking, I raise the 5th just so it comes off the B&W, release handle and pull away.
BTW, those some darn good "crude" drawings!!!
AC
2017 F350 DRW XLT, CC, 4x4, 6.7
2018 Big Country 3560 SS
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
RobWNY
Jamestown, NY
Posted: 08/16/20 08:58am Link  |  Quote  |  Print  |  Notify Moderator
ACZL wrote:
Rob,
AC
Thanks for the compliment. All the credit goes to the computer drawing program I used. How was your vacation?
2020 Silverado 2500HD LT, CC, 4X4 6.6 Duramax
2021 Grand Design Reflection 311BHS
You can't put a porcupine in a barn, set it on fire, and expect to make licorice.
C Schomer
Pueblo West, Co.
Posted: 08/16/20 05:51pm Link  |  Quote  |  Print  |  Notify Moderator
I have the same thing as the OP and by the time the pin is into the hitch far enough to close the jaws, the plates are pressed together, parallel. This summer I started plugging in the cord while hitching and unhitching and manually holding the trailer brakes, so not to slide the rv off the leveling blocks and that makes jaw closing very positive and no worries about pressure in the hitch bag. 80 psi keeps my hitch plates horizontal, traveling. Craig
2012 Dodge dually diesel. CCLB 4wd, custom hauler bed.
2008 Sunnybrook Titan 30 RKFS Morryde and Disc brakes
WHOEVER INVENTED WORK DIDN'T HAVE AN RV!
RobWNY
Jamestown, NY
Posted: 08/16/20 06:21pm Link  |  Quote  |  Print  |  Notify Moderator
That's good to know Craig. I've never plugged in before hitching up so if I continue having issues, I'll give that a try.
RCMAN46
NorthWest
Posted: 08/16/20 06:39pm Link  |  Quote  |  Print  |  Notify Moderator
If you leave your chocks in place there should not be a need to use the trailer brakes.
Also should have chocks in place when doing the tug test and before unhitching.
The standard electric trailer brakes will not be active until a tire rotates about 1/4 turn.
larry barnhart
wenatchee. wa usa
Posted: 08/18/20 01:32pm Link  |  Quote  |  Print  |  Notify Moderator
I just removed our airhitch from our truck and it was heavy. Rails were hard to remove also but an awesome experience having it and the air pin is also great.
chevman
chevman
2021 Jayco Hawk 28RL
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
 > Pin Box with Air
